LG QNED90T Review: Is This 4K LCD a Perfect Fit for Your Home Theater?
windstri85
First Impressions​
The LG QNED90T has a very similar design to theLG QNED90. It has thin bezels on three sides, which are barely noticeable when watching TV, and a thicker bottom bezel. Its not quite as nice looking as LGs OLED TVs, but it still looks premium overall.
The back of the TV is mostly made of metal. Most of the inputs are on the far left side of the TV when facing the front, so they're accessible if you have the TV wall-mounted. There are plastic clips on each side of the back, and the feet each have a slot that can be used to help withcable management. Unfortunately, the top of the back of our unit is warped near the VESA mounting points.
The LG QNED90T is well-built overall. It's mostly made of metal materials that feel solid, and the two feet hold the TV well with minimal wobble when pushed on. Unfortunately, the back of our unit is warped near the top VESA mounting points.
LG QNED90T​
$1896.99​
Model Year​
2024​
Specific Uses​
Entertainment, Gaming​
E-Manual: Yes, Remote: Magic Remote MR24, Power Cable: Yes (attached), Quick Start Guide: Yes, Remote Control Battery: Yes (AA x 2EA)​
Highlight
QNED Contrast: Mini LED technology for bright colors, independent backlight zones for dark-level detail and deep blacks.
Quantum Dot NanoCell Color: Nanocell layer enhances color richness and contrast.
Mini LED Backlighting with Precision Dimming: 40x smaller LEDs, thousands of individually controlled dimming zones for improved blacks and brightness.
Dolby Vision, Filmmaker Mode, and Dolby Atmos: Enhanced color, contrast, brightness, and immersive sound experience.
a8 AI Processor: AI-powered picture refinement, automatic setting adjustments, and Multi View with split-screen capability.
System​
LG QNED90T​
Operating System​
WebOS​
Internet Applications​
Disney Plus, HBO Max, Netflix, Prime Video, Apple TV and more.​
Infrared​
Voice Control​
Voice​
Overall Impression: The LG QNED90T TV offers a user-friendly experience with its fast and customizable webOS interface, featuring user profiles for tailored home pages. While it boasts a robust selection of apps and casting capabilities, it does suffer from a noticeable bug related to the Game Optimizer setting that may hinder access to certain picture modes. Additionally, while options to declutter the home screen from ads are available, the presence of ads on the apps page remains a drawback. Overall, the TV provides solid performance with some minor usability issues.
LG QNED90T​
Aspect Ratio​
16:9​
Display Technology​
Mini Led​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
120 Hz​
Viewing Angle​
170 Degrees​
HDR Format​
HLG, HDR10, Dolby Vision​
Backlight Technology​
Mini-LED​
Backlight Setting​
Precision Dimming​
Mini LED Backlighting with Precision Dimming​
Motion Enhancement​
Motion Pro​
Viewing Experience
The LG QNED90T delivers impressive contrast with deep blacks, particularly when local dimming is enabled, although its blooming performance is only acceptable, with visible blooming around bright highlights. The TV performs well in HDR with a strong color gamut, but vibrant colors can appear undersaturated. Overall, its gray uniformity is satisfactory but marred by a dirty screen effect in the center and vignetting at the corners. Black uniformity is outstanding with local dimming, although disabled, blacks can appear cloudy. The viewing angle is limited, making it less ideal for wide seating arrangements, and while reflection handling is good, direct reflections can be distracting. Additionally, the use of a BGR subpixel layout may affect text clarity for PC use, but does not hinder video or gaming performance. Overall, the LG QNED90T is a strong performer in contrast and HDR color, with some limitations in blooming and viewing angles.
Audio​
LG QNED90T​
Audio Channels​
2.2​
Surround Sound​
DTS:X, Dolby Atmos​
Audio Output​
Surround​
Audio Input​
HDMI, Optical​
Speaker Description​
Dolby Atmos, Down Firing, 2.2 Channel, AI Sound Pro​
Speaker Output Power​
40 Watts​
Audio Experience
The TV offers a decent audio experience with clear dialogue and some bass presence, making it suitable for general viewing. However, it struggles with sound balance at higher volume levels, leading to a less satisfactory performance when pushed to maximum. The distortion levels are manageable at moderate volumes, but they become more pronounced as the volume increases, which may detract from the overall listening experience.
LG QNED90T​
Smartphone​
Tuner Type​
ATSC1.0 (Terrestrial), QAM (Cable)​
D x W x H​
14.1"D x 65.9"W x 40.4"H​
Mount Standard​
400 x 400 mm​
Power Consumption​
165 Watts​
Line Voltage​
100-240 VAC 50-60 Hz​
Built-In Speaker, Game Mode, Multiple Voice Assistance, Flat, Amd freesync​
Motion Smoothing
The LG QNED90T offers a solid performance with good detail preservation in low-quality content, though it struggles with noticeable artifacts in dark scenes. Its impressive response time is somewhat undermined by blurring during fast motion and black smearing during dark transitions. The use of pulse width modulation for backlight dimming introduces flicker, which may affect sensitive viewers, particularly in specific picture modes. While it features motion interpolation to enhance clarity, the effectiveness diminishes with fast-moving content, leading to distracting artifacts. Overall, the TV delivers a mix of strengths and weaknesses, particularly in motion handling and dark scene performance.
Connectivity​
LG QNED90T​
Bluetooth Version​
5.1​
Screen Mirroring​
AirPlay 2​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
2​
USB2.0 Ports​
2​
HDMI Ports​
4​
Connector Type​
USB, RS232C, Optical, Ethernet, HDMI
Signal Format​
terrestrial, cable​
Sharing Direction​
Mobile to TV​
Hardware Interface​
S/PDIF, Bluetooth, USB, Ethernet, HDMI
Connecting TV
The LG QNED90T delivers an outstanding gaming experience with its exceptionally low input lag, particularly in Game Optimizer mode. It is fully equipped to handle the advanced capabilities of current gaming consoles, offering support for both 1440p at 120Hz and 4K at 120Hz, along with HDMI Forum VRR and Auto Low Latency Mode for seamless gameplay. With full 48 Gbps bandwidth support across all four HDMI 2.1 ports, the TV can accommodate multiple high-bandwidth devices effortlessly. Additionally, the inclusion of eARC ensures high-quality, uncompressed audio transmission, making it compatible with various audio formats for an enhanced audiovisual experience. Overall, the LG QNED90T is a robust choice for gamers and home theater enthusiasts alike, providing a responsive and high-quality viewing experience.
User Feedback​
Pros
• Easy setup with AI assistant that assists in initial configuration.
• Fluid and convenient interface with quick response times.
• Sleek design with thin bezels enhancing the big screen experience.
• Universal remote with a track pad feature for easy navigation.
• Outstanding colors with deep blacks, comparable to OLED quality in 4K movies.
• Quick game setup with a mind-blowing gaming experience.
Cons
• Occasional blooming may occur, though it's not frequent.
Eye comfort mode may adjust brightness too high at night, requiring manual adjustment.
• Glossy screen reflects light, making it difficult to view in bright settings.
• Glaring lights behind the viewer can hinder focus on the screen.
Overall Impression
This TV offers exceptional visual quality, rivaling OLED screens, making it a great choice for movie enthusiasts and gamers alike. While it has some minor drawbacks related to reflections and occasional blooming, its strengths in setup, interface, and picture quality make it a worthy investment, especially at the current price point of $1499.
