LG G4 Review: Is OLED Evo the Right Choice for Your Next Smartphone?
cruets620
First Impressions​
The LG G4 OLED has a very sleek and modern design. Its essentially the same as last yearsLG G3 OLED, with very thin bezels and a flat side profile, which means it's completely flush when wall-mounted.
The back of the TV has a very clean and minimalistic look. Its made of textured metal with a metallic silver border at its edges. There arerecessed cutoutsin the back that can be used to funnel cables through, and those cables can be funneled through the intuitive stand forcable management. If you want to wall-mount the TV,you can still do so, but the 55-inch and 65-inch models dont come with LG's Slim Wall Mount.
The LG G4 TV has outstanding build quality. Its made of metal throughout, so the construction is solid, and the TV doesnt flex except for some very minor flex in the middle of the back panel. It does wobble a bit more than other LG OLEDs with a stand, but this doesn't cause any issues.
LG G4​
$2196.99​
Model Year​
2024​
Specific Uses​
Entertainment, Gaming​
E-Manual: Yes, Remote: Magic Remote MR24 with NFC, Power Cable: Yes (attached), Quick Start Guide: Yes, Remote Control Battery: Yes (AA x 2EA)​
Highlight
Display Size: 55-inch
Display Type: 4K OLED
Self-lit Pixels: Over 8 million
Color Volume: 100%
Brightness Technology: Brightness Booster Max
Design: Seamless wall-mount
Audio Technology: Dolby Atmos
Video Features: Dolby Vision, Filmmaker Mode
Usage: Suitable for displaying artwork/photos when not in use
System​
LG G4​
Operating System​
WebOS​
Internet Applications​
Disney Plus, HBO Max, Netflix, Prime Video, Apple TV and more.​
Bluetooth​
Remote Control, App Control, Voice Control​
Voice​
The LG G4 OLED TV offers a sleek and user-friendly experience with its 2024 webOS, featuring fast navigation and customizable user profiles. However, it does have some notable bugs that can disrupt functionality, particularly related to the Game Optimizer setting and occasional black screens during resolution changes. While the Home Settings menu allows for a cleaner interface by removing some ads, the inability to eliminate ads on the apps page can detract from the overall experience. On the positive side, the TV boasts a robust app selection and supports content casting, enhancing its versatility for viewers. Overall, while the TV has strong potential with its software and features, the presence of bugs may affect user satisfaction.
LG G4​
Aspect Ratio​
16:9​
Display Technology​
OLED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
120​
Response Time​
0.1 Milliseconds​
Viewing Angle​
170 Degrees​
HDR Format​
HLG, HDR10, Dolby Vision​
Backlight Technology​
Self-Luminous​
Backlight Setting​
Pixel Dimming​
a11 AI Processor 4K​
Motion Enhancement​
OLED Motion​
Viewing Experience
The LG G4 OLED TV offers an impressive visual experience, characterized by remarkable contrast and an almost infinite contrast ratio due to its self-lit pixels. The absence of local dimming eliminates blooming effects, allowing for bright highlights to coexist seamlessly with deep blacks, especially in dark viewing environments. The TV excels in color reproduction, showcasing an excellent color gamut with strong coverage of the DCI-P3 color space, although it shows some undersaturation in reds and greens. Gray uniformity is commendable, with only faint vertical lines that become less noticeable over time. Additionally, the wide viewing angles ensure consistent image quality from various positions, making it ideal for group viewing. The LG G4 also boasts exceptional reflection handling, effectively minimizing glare from direct and indirect light sources. The incorporation of Micro Lens Array technology enhances brightness without overheating, although the 97-inch model lacks this feature. Overall, the LG G4 OLED stands out for its impressive picture quality and performance, making it a compelling choice for home entertainment.
Audio​
LG G4​
Audio Channels​
4.2​
Surround Sound​
DTS:X, Dolby Atmos​
Audio Output​
Surround​
Audio Input​
HDMI​
Speaker Description​
Dolby Atmos, Down Firing, 4.2 Channel, AI Sound Pro​
Speaker Output Power​
60 Watts​
Audio Experience
The LG G4 OLED TV delivers a well-balanced sound profile, making dialogue clear and understandable. It offers a surprising amount of bass for a television, enhancing the overall audio experience. While the TV doesn’t get very loud, it maintains good sound quality even near maximum volume. Distortion levels are manageable, with only a slight increase at higher volumes, ensuring a decent listening experience at moderate levels. Overall, the LG G4 OLED TV provides solid audio performance that complements its visual capabilities.
LG G4​
Smartphone​
Tuner Type​
ATSC1.0 (Terrestrial), QAM (Cable)​
D x W x H​
10.4"D x 48.11"W x 27.68"H​
Mount Standard​
300 x 200 mm​
Power Consumption​
139.2 Watts​
Line Voltage​
100-240 VAC 50-60 Hz​
Built-In Speaker, Nvidia G Sync, Game Mode, Flat, Amd freesync​
Motion Smoothing
The LG G4 TV delivers impressive performance with low-quality content, effectively smoothing out images while preserving detail and avoiding noticeable macro-blocking in dark areas. Its response time is nearly instantaneous, resulting in sharp motion and minimal blur, particularly at higher refresh rates. However, there is some persistence blur at 60Hz that may be noticeable to gamers. The lack of a traditional backlight and the absence of pulse-width modulation contribute to a viewing experience that is mostly flicker-free, though sensitive viewers might detect a slight dip in brightness linked to the refresh rate. Additionally, the optional motion interpolation feature enhances slower scenes but can introduce haloing and artifacts in fast-moving action, especially when overused. Overall, the LG G4 TV excels in motion clarity and detail retention, making it a strong choice for various viewing experiences.
Connectivity​
LG G4​
Bluetooth Version​
5.1​
Screen Mirroring​
AirPlay 2​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
3​
USB2.0 Ports​
3​
HDMI Ports​
4​
Connector Type​
USB, RS232C, Optical, Ethernet, HDMI​
Sharing Direction​
Mobile to TV​
Hardware Interface​
S/PDIF, Bluetooth, USB, Ethernet, HDMI​
Connecting TV
The LG G4 offers an impressive gaming experience with exceptionally low input lag, particularly when utilizing the Game Optimizer feature. This makes it highly responsive, ideal for gamers who require minimal delay. It fully supports high resolutions and refresh rates, including 1440p at 120Hz and 4K at 120Hz, along with HDMI Forum VRR, ensuring compatibility with the latest gaming consoles and high-end PCs. The TV's four HDMI 2.1 ports provide ample bandwidth for multiple high-performance devices. However, users should be aware of potential issues with the HDMI 2 port, as some units may experience black screens or other display anomalies when switching sources. Despite the lack of ATSC 3.0 support for 4K over-the-air broadcasts, the LG G4 stands out for its extensive audio format compatibility, particularly with DTS, enhancing the overall viewing experience for media enthusiasts.
User Feedback​
• Excellent picture quality
• Great brightness
• Ease of operation and setup
• Outstanding for gaming and movie watching
• Poor user interface (UI)
• LG Channels frequently crashes and freezes
• Unremovable superfluous apps
• Outdated functionality for a high-end TV
• Overall performance does not meet expectations for a $2,000 TV
This TV excels in picture quality and brightness, making it a solid choice for gamers and movie enthusiasts. However, the significant shortcomings in user interface and functionality, particularly with LG Channels and WebOS, detract from the overall experience. For a premium price point, the poor software performance is disappointing and may lead users to reconsider their purchase.
