LG C4 OLED Review: Full Feature Performance Meets Stunning Visuals
Hardon Williams
First Impressions​
The LG C4 has a very sleek and modern design. Its very similar to last yearsLG C3 OLED, but the back has a unique stone-like finish. The TV's bezels are incredibly thin, so you barely see them while watching.
The back of the TV is made from plastic that is grainy to the touch and has a unique stone-like finish that really separates it from other TVs. Outside of that, the back is the same as theLG C3 OLED, with a large plastic central panel that houses the inputs. The inputs face the right which makes them easy to access if you have the TV on the stand, but they're still hard to reach when the TV is wall-mounted.The back of the TV hasclipsthat you can funnel cables through, and then they can be put through theclip on the standto help withcable management.
The build quality of this TV is incredible overall. Theres a bit of flex near the VESA mounting points, but this is common and doesnt cause problems. The TV looks and feels premium.
LG C4​
$1496.99​
Model Year​
2024​
Specific Uses​
Entertainment, Gaming​
E-Manual: Yes, Remote: Magic Remote MR24, Power Cable: Yes (attached), Quick Start Guide: Yes, Remote Control Battery: Yes (AA x 2EA)​
Highlight
Display Size: 65 inches
Resolution: 4K
Panel Type: OLED
Self-lit Pixels: Over 8 million
Color Volume: 100%
Color Fidelity: 100%
Processor: LG a9 AI Processor Gen7
Refresh Rate: 120Hz
Response Time: 0.1ms
Gaming Support: NVIDIA G-Sync, AMD FreeSync Premium, VRR
HDR Support: Dolby Vision
Audio Technology: Dolby Atmos
Special Mode: FILMMAKER MODE
HDMI Ports: 4 (HDMI 2.1)
USB Ports: 3
Smart Features: webOS Re:New Program (5 years updates)
Streaming Support: Prime Video and more
System​
LG C4​
Operating System​
WebOS​
Internet Applications​
Disney Plus, HBO Max, Netflix, Prime Video, Apple TV and more.​
Bluetooth​
Remote Control, App Control, Voice Control​
Voice​
The LG C4 TV offers a fast and user-friendly experience with its 2024 webOS interface, featuring customizable user profiles that enhance personalization. While it provides a wide selection of apps and supports content casting and USB playback, it does encounter a notable bug that causes occasional black screens when rapidly changing resolutions and refresh rates, requiring a power cycle to resolve. The option to clean up the home screen by removing ads and suggestions is a positive feature, although ads on the apps page cannot be removed. Despite the issue, the TV's strengths in usability and content accessibility make it a compelling choice for users looking for a streamlined smart TV experience.
LG C4​
Aspect Ratio​
16:9​
Display Technology​
OLED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
120​
Response Time​
0.1 Milliseconds​
HDR Format​
HLG, HDR10, Dolby Vision​
Backlight Technology​
Self-Luminous​
Backlight Setting​
Pixel Dimming​
a9 AI Processor 4K Gen7​
Motion Enhancement​
OLED Motion​
Viewing Experience
The LG C4 delivers an impressive viewing experience, particularly excelling in contrast and black levels thanks to its OLED technology. With nearly infinite contrast ratios, it showcases bright highlights against deep blacks, making it ideal for dark room environments. The absence of local dimming eliminates blooming, ensuring sharp visuals even with bright elements nearby. The color gamut is strong, particularly in the DCI-P3 color space, although some colors are undersaturated, especially in the Rec. 2020 spectrum. The TV provides excellent gray uniformity and black uniformity, with minimal issues like faint vertical lines being imperceptible at normal viewing distances. Its wide viewing angle enhances the viewing experience for larger seating arrangements without significant degradation of image quality. Reflection handling is outstanding, effectively managing both indirect and direct reflections. However, there is a notable green tint issue that varies by unit, although most users may not be significantly affected. Overall, the LG C4 stands out for its superb performance characteristics, making it a compelling option for OLED enthusiasts.
Audio​
LG C4​
Audio Channels​
2.2​
Surround Sound​
DTS:X, Dolby Atmos​
Audio Output​
Surround​
Audio Input​
HDMI​
Speaker Description​
Dolby Atmos, Down Firing, 2.2 Channel, AI Sound Pro​
Speaker Output Power​
40 Watts​
Audio Experience
The LG C4 offers an adequate frequency response with a well-balanced sound profile that ensures clear dialogue. However, its built-in speakers lack sufficient bass impact and struggle to reach high volumes without introducing noticeable distortion and artifacts. While the distortion handling is decent at moderate levels, the overall sound performance may leave users wanting more in terms of volume and bass depth.
LG C4​
Smartphone​
Tuner Type​
ATSC1.0 (Terrestrial), QAM (Cable)​
D x W x H​
9.1"D x 56.73"W x 34.65"H​
Mount Standard​
300 x 200 mm​
Power Consumption​
145.3 Watts​
Line Voltage​
100-240 VAC 50-60 Hz​
Built-In Speaker, Nvidia G Sync, Game Mode, Flat, Amd freesync​
Motion Smoothing
The LG C4 TV offers impressive performance, particularly in handling low-quality content, with effective smoothing and excellent detail preservation in darker scenes. Its response time is nearly instantaneous, resulting in sharp motion clarity and minimal blur during fast-moving visuals, although some persistence blur may be present at 60Hz. While it doesn't rely on traditional backlighting or PWM for dimming, there is a slight brightness dip related to the refresh rate, which is generally not noticeable but may affect sensitive viewers. The optional motion interpolation feature enhances motion in slower scenes, but can introduce noticeable haloing and artifacts in fast-paced action, especially with aggressive settings. Overall, the LG C4 excels in motion clarity and low-quality content handling, making it a strong choice for a variety of viewing experiences.
Connectivity​
LG C4​
Bluetooth Version​
5.1​
Screen Mirroring​
AirPlay 2​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
3​
USB2.0 Ports​
3​
HDMI Ports​
4​
Connector Type​
USB, RS232C, Optical, Ethernet, HDMI​
Sharing Direction​
Mobile to TV​
Hardware Interface​
S/PDIF, Bluetooth, USB, Ethernet, HDMI​
Connecting TV
The LG C4 offers an outstanding gaming experience with exceptionally low input lag, particularly when utilizing the Game Optimizer feature. This results in minimal delay between controller actions and on-screen responses, making it ideal for gamers seeking responsiveness. The TV is fully compatible with high-resolution gaming options, supporting up to 4K at 120Hz and 1440p at 120Hz, along with HDMI Forum VRR and Auto Low Latency Mode for seamless transitions. Its four HDMI 2.1 ports provide full 48Gbps bandwidth, accommodating multiple high-bandwidth devices efficiently. Additionally, the support for various audio formats, including DTS, enhances the viewing experience for media enthusiasts. Overall, the LG C4 is a well-rounded television that excels in gaming performance and media playback versatility.
User Feedback​
Pros
• Amazing picture quality with vibrant colors and deep blacks
• Excellent gaming performance, particularly with PS5
• Quick and intuitive remote control functionality
• Automatic picture adjustment based on input type
• Impressive native sound quality for built-in speakers
• Intuitive on-screen menus and navigation
Cons
• Clunky operating system with limited app availability
• Sound quality is only decent; a dedicated sound system is recommended for the best experience
• Learning curve with remote control features
Overall Impression
This TV delivers exceptional picture quality and a great experience for gaming and movie-watching, making it a premium choice without exceeding budget constraints. While the operating system and sound could be improved, these issues are manageable, especially with the option to use external devices. Overall, it more than exceeds expectations and stands out as a solid investment.
