Dangbei Projector
Appotronics A300 is a laser projection TV with a price of $5000. The brightness is the biggest advantage of this laser projection TV. However, the screen contrast is only 3001-5000: 1, and the configuration is relatively low. This time happens to be high. , High contrast, with 1400ANSI lumens Dangbei F1 for comparison, see how the effect will be.
The laser light source used by Appotronics A300 has obvious advantages in light source. At the same time, it has ultra-short-throw technology, which projects a large picture. .
Judging from the comparison of this photo, the brightness advantage of Appotronics A300 is still very obvious, it is still very blue, but when the color and details of F1 are not lost
Looking at the comparison of this fruit, it is obvious that the picture of Appotronics A300 will be slightly yellowish, the performance of yellow bananas is acceptable, and the red part is not satisfactory, or it may be because the picture is too bright.
In the last comparison, it can be seen that the brightness of the light peak A300 interferes with the color. The brightness is partially exploded. It can only be said that the advantage of the laser light source is more obvious. When the F1 is in a dark light environment, the feedback to the human eye is more Comfortable, the overall effect can be said to be a high level of LED projector. In terms of cost performance, more than $5000 light peak A300 and $600 Dangbei F1, obviously Dangbei F1 is more budget, aside from the brightness of the projector, the image quality and color are completely worth the price of the $5000 laser projection TV, and The brightness of 1400ANSI lumens can fully meet the daily home.
