Kodak Ultra Mini vs KODAK Luma 150 vs TMY Ultra Mini Projector: Which DLP Mini Projector is a Better Choice?
cruets620
Kodak Ultra Mini Portable Projector​
KODAK Luma 150 Mini Projector​
TMY Ultra Mini Projector​
$179.99​
$219.99​
$149.99​
Home Cinema, Gaming, Business​
Home Cinema​
Home Cinema, Gaming​
User Manual, Power Cord, HDMI Cable​
Remote, user manual, Speaker​
Adaptor, User Manual, Remote, HDMI Cable, Cleaning Kit​
Optical Engine: Advanced DLP with superior LED brightness, exceptional color accuracy, pristine picture quality (best in dark to dim-lit rooms)
Size: Smallest and lightest DLP projector, palm-sized, portable
Connectivity: Onboard media player, built-in speakers, 3.5mm input, integrated HDMI, USB, MicroSD
Ease of Use: Simple plug-and-play with no complicated buttons or menus
Color Output: Displays 16.7 million colors for rich detail in games, movies, and slideshows
Projection Size: Up to 150”
Resolution: 854 x 480, Supports 4K
Brightness: 60 ANSI lumens
Contrast Ratio: 1000:1
Ports: HDMI & Micro USB
Wireless Features: Airplay & Miracast
Battery Life: Up to 2.5 hours
Built-in Speaker: Yes
Controls: Illuminated onboard controls
Content Restrictions: Cannot mirror copyrighted content from streaming services; requires external streaming device for such content.
Dimensions: 3.82*3.42*1.33 in
Weight: 0.53 lb
Battery Capacity: 5000mAh
Playback Time: 3.5 hours
Projection Technology: DLP
WiFi Connectivity: 5G
Audio Feature: Bluetooth speaker connectivity
Connectivity Ports: HDMI, MicroSD, USB
Unboxing Experience​
Kodak Ultra Mini Portable Projector:​
The Kodak Ultra Mini Portable Projector is impressively small and lightweight, easily fitting in the palm of my hand. Its compact design makes it incredibly portable, ideal for anyone looking for a travel-friendly option. The build quality feels solid, suggesting durability despite its diminutive size. The sleek design and modern aesthetics are appealing, making it a stylish addition to my tech collection.
KODAK Luma 150 Mini Projector:​
The Kodak Luma 150 projector boasts a compact and portable design, easily fitting into a pocket or small bag, making it an attractive option for those needing on-the-go functionality. Upon unboxing, the projector feels solidly constructed, giving off a premium vibe despite its small size. The layout of the buttons on top is a bit clumsy, requiring a tap on the center to access the controls, but overall, it maintains a sleek and modern aesthetic.
TMY Ultra Mini Projector:​
From the moment I unboxed the TMY Ultra Mini Projector, I was struck by its sleek and compact design. It's surprisingly lightweight and fits comfortably in the palm of my hand, making it incredibly portable. The minimalist aesthetic and modern finish give it a stylish appeal, and I appreciate how it can easily slip into any bag or even a large pocket, making it a perfect travel companion for movie nights or presentations on the go.
80 Inches - 80 Inches​
80 Inches - 150 Inches​
5 Meters - 5 Feet​
6 Feet - 8.5 Feet​
5 - 0.5 Meters​
1000:1​
3500:1​
> 1000:1​
640 x 360 Pixels​
360 x 640 Pixels​
640 x 360​
640 x 360​
35 Lumen​
60 Ansi lumen​
LED​
RGB​
DLP​
DLP​
DLP​
The image quality is surprisingly good for such a compact device, providing a clean and crisp picture even in moderately lit rooms. However, the brightness level can be a limiting factor; it performs best in dark environments and may struggle in brighter settings. Focusing the image can be a bit tricky, and I faced challenges keeping the image sharp over extended use. I also encountered issues with the projector not recognizing input from certain devices, which was frustrating and hindered the viewing experience.
The viewing experience with the Luma 150 is a mixed bag. While it excels in brightness and clarity in low-light settings, the native resolution of 480p leaves something to be desired, resulting in a slightly grainy image when projecting from my iPhone. The projector is best suited for tracing artwork or small-scale viewing rather than large presentations or movie nights. Additionally, I found that for optimal performance, using an external speaker greatly enhances the audio experience, as the built-in speaker lacks sufficient volume and clarity.
The viewing experience with this ultra mini projector exceeded my expectations. The image quality is stunning, with vibrant colors and sharp details that really bring movies and presentations to life. While it performs best in dim lighting, I was pleasantly surprised to find that it still delivered a clear picture even in ambient light. The flexibility of projecting onto a large wall or a makeshift screen adds to its versatility, and the fact that it supports 1080P resolution is a significant plus for home entertainment.
Built-In Speaker, Portable, Pocket, Built-In Battery, Built-In Media Player​
Portable​
Built-In Speaker, Portable, Lightweight, Ultra Short Throw, Wi-Fi Ready​
AVC​
MP4​
5 Watts​
1 Watts​
30000 Hours​
3000 Hours​
android, ios​
android, vera, ios​
Button Control​
App​
App​
MicroSD, USB, HDMI, 3.5mm Jack​
USB​
Laptop, Computer, Tablet​
iPhone, PC, Smartphone, MAC, Android​
9.25 watts​
5 watts​
15 watts​
Mount Type​
Tripod Mount​
Wall Mount​
Tabletop Mount/Ceiling Mount/Floor Mount/Tripod Mount​
3"L x 3"W x 0.8"H​
3.9"L x 3.9"W x 0.89"H​
3.78"L x 3.38"W x 1.14"H​
Setting up the projector was straightforward and user-friendly. The projector operates well with an overhead mount or tripod and pairs easily with various devices via HDMI or USB-C cables. However, I found that I needed to purchase additional adapters separately, which was a bit of an inconvenience. The absence of Bluetooth capabilities is also a downside, as it limits wireless connectivity options. Overall, once connected, the setup process is smooth, allowing for a quick start to projecting content.
Setting up the Kodak Luma 150 was relatively straightforward, with a manual and various connection cables included in the package. I found it easy to connect the projector to my devices, whether via HDMI or wirelessly through Wi-Fi. However, I did experience some initial difficulties when trying to connect to the internet; I had to ensure I was on the correct Kodak network first. Once connected, the screen mirroring function worked well, especially with my iPhone, allowing for seamless operation.
Setting up this projector was a breeze. The user-friendly interface and straightforward controls allowed me to get started in just a few minutes. It supports various connectivity options, including HDMI, USB, and Bluetooth, enabling me to connect seamlessly to my smartphone, laptop, or streaming devices. Although I initially faced some challenges with screen mirroring from my iPhone due to copyright restrictions, I quickly discovered that using a streaming device like a Fire TV Stick solved the problem effortlessly.
• Very portable and lightweight
• Good image quality in dark environments
• Solid build quality
• Requires additional adapters not included with the purchase
• Limited brightness in well-lit rooms
• Focus can be difficult to maintain
• No Bluetooth support for wireless connections
The Kodak Ultra Mini Portable Projector has a lot of potential, especially for those needing a compact solution for presentations or casual viewing. Its ease of use and decent image quality make it a viable option for art projects or small gatherings. However, the need for additional purchases, limitations in brightness, and focus issues detract from its overall performance. While it may not replace a higher-end projector, it serves its purpose well for portable use, making it a worthwhile investment for those who prioritize size and convenience over top-tier performance.
• Compact and easy for travel.
• Convenient and easy to set up.
• Simple and reliable connection.
• Adjustable quality settings.
• Speakers could be louder.
• Battery life is only about 1 and ½ hours.
• It takes about the same time, maybe longer to charge the battery as it lasts.
Overall, the Kodak Luma 150 projector has its strengths and weaknesses. It is an excellent choice for those needing a portable projector for tracing or casual viewing, especially for art projects, but it is not without its flaws. The battery life could be significantly improved, and the image quality is only moderate at best. While I appreciate its portability and ease of use, I found it lacking for serious movie-watching or detailed presentations. If you're looking for a budget-friendly option for light use, it may fit the bill, but if you require high-quality projection, you might want to explore higher-end alternatives.
• Excellent image quality with vibrant colors.
• Compact and lightweight design for easy portability.
• User-friendly setup with multiple connectivity options.
• Impressive battery life lasting around 2-3 hours on a single charge.
• Affordable price with premium features.
• Ability to connect to Bluetooth speakers for enhanced audio.
• Built-in speaker lacks volume and quality.
• Requires frequent refocusing until the unit warms up.
• Limited functionality with certain streaming services due to copyright issues.
• Remote control needs a line-of-sight to operate, and it cannot power the unit on/off.
Overall, the TMY Ultra Mini Projector is a remarkable device that combines excellent performance, portability, and ease of use in a compact package. Despite a few minor drawbacks, such as the sound quality and the need for frequent refocusing, I find it to be an incredibly valuable tool for both entertainment and presentations. I highly recommend this projector to anyone seeking a reliable and versatile solution for on-the-go viewing or casual movie nights at home. It truly stands out as an impressive piece of technology that I can see myself using for years to come!
Hellopi314
The KODAK Luma 150 Mini Projector is great, but the only bummer is you can't stream on it. Other than that, it does its job well!
I’m super impressed with the TMY Ultra Mini Projector! I didn’t expect much since it’s tiny and battery-powered, but wow, the picture is super clear and bright! The sound’s decent too, considering the size. Overall, I’m really happy I bought it!
Elfman72
Just got the TMY Ultra Mini Projector a few weeks ago and I'm loving it! Super easy to set up with my Wi-Fi, and I can cast from my Apple devices while jamming on my Doss Soundbox Pro. Perfect for movie nights outside by the firepit with Max, Netflix, Prime, you name it!
The TMY Ultra Mini Projector is awesome! The picture looks great, and the Bluetooth lets you hook up a louder speaker easily. Screen mirroring? No problem—works like a charm with no extra apps needed, unlike other brands. With all these features, it's a steal!
