Kodak Ultra Mini vs EZCast J4 vs TMY Ultra Mini: Which Portable Projector with Built-in Speaker Should You Choose?
Bellmeister
Kodak Ultra Mini Portable Projector​
EZCast J4 Projector​
TMY Ultra Mini Projector​
$99​
$149.99​
Indoor​
Home Cinema, Gaming​
Battery​
Adaptor, User Manual, Remote, HDMI Cable, Cleaning Kit​
Optical Engine: Advanced DLP with superior LED brightness, exceptional color accuracy, and pristine picture quality (optimal in dark to dim-lit rooms)
Size: Smallest and lightest DLP projector, portable for easy transport
Compatibility: Onboard media player with built-in speakers, 3.5mm input, HDMI, USB, and MicroSD connectivity
Ease of Use: Simple plug-and-play operation with no complicated buttons or menus
Color Capability: Displays 16.7 million colors for rich detail in games, movies, and slideshows
Product Type: Rechargeable Movie Projector
Weight: 14.1 ounces
Dimensions: 4.53 x 4.53 x 1.26 inches
Brightness: 300 Lumens
Display Size: Up to 100 inches
Technology: DLP
Resolution: 1080P
Contrast Ratio: 5000:1
Battery Life: 5 hours
Lamp Life: Over 20,000 hours
Connectivity: 2.4G/5G WiFi, HDMI, USB, Audio Jack
Compatibility: iOS & Android, MacBook & Windows, TV sticks, gaming consoles
Features: Automatic vertical keystone correction, Bluetooth speaker integration
Warranty: 1 year, OTA upgrade capability
Dimensions: 3.82*3.42*1.33 in
Weight: 0.53 lb
Battery Capacity: 5000mAh
Playback Time: 3.5 hours
Projection Technology: DLP
WiFi Connectivity: 5G
Audio Connectivity: Bluetooth
Ports: HDMI, MicroSD, USB
Unboxing Experience​
Kodak Ultra Mini Portable Projector:​
The Kodak Ultra Mini Portable Projector exudes a solid and high-quality feel, particularly impressive for a device in this price range. Its compact design makes it incredibly portable, making it an appealing choice for users who need something lightweight and easy to transport. I appreciate the thoughtful design elements, such as lens protection, and the overall aesthetic is quite attractive, making it a nice addition to any setup without taking up much space.
EZCast J4 Projector:​
Upon first glance, this device impresses with its petite size, fitting comfortably in the palm of my hand. Its compact design makes it incredibly portable, which is a significant plus for anyone on the go. The overall aesthetic is sleek and modern, giving it a fresh look that I find appealing.
TMY Ultra Mini Projector:​
Upon unboxing the TMY Ultra Mini Projector, I was immediately struck by its sleek and compact design. This tiny device fits comfortably in the palm of my hand, making it incredibly portable and perfect for travel. Its modern aesthetic is both appealing and practical, allowing it to blend seamlessly into any setting, whether at home or outdoors. The lightweight build means it can easily slip into a bag or even a pocket, which is a significant advantage for anyone on the go.
1E+1 Inches - 100 Inches​
0.86 Meters - 2.88 Meters​
5 - 0.5 Meters​
5000:1 Pixels​
> 1000:1​
1920x1080 Pixels​
360 x 640 Pixels​
640 x 360​
10000 Lumen​
DLP​
DLP​
DLP​
The image quality is surprisingly good given the projector's small size, offering a clean and crisp display, particularly in darker environments. I found that the projection is better appreciated in dim lighting, although it performs adequately in well-lit conditions too. The large projection size at short distances is a definite plus, and while the resolution isn't on par with high-end options, it meets my expectations for casual use in art installations and presentations. However, I did notice some discoloration in certain areas, which might detract from the overall viewing experience for more critical applications.
The viewing experience is nothing short of impressive for such a small device. The clarity and brightness are standout features that enhance any content I decide to view. I was genuinely surprised by how well it performs, making it a joy to use for various purposes.
The viewing experience with this ultra mini projector has been impressive. The image quality is vibrant and clear, with sharp details that bring movies and presentations to life. While it excels in dimmer lighting conditions, I found that it still performed adequately in ambient light, providing a decent picture quality even during the day. The native output supports 360P, but it can handle higher resolutions for media playback, and I was pleased with the overall brightness and clarity of the image, especially considering the projector's small size.
Portable, Built-in Battery, Speaker, Wi-Fi Ready​
Built-In Speaker, Portable, Lightweight, Ultra Short Throw, Wi-Fi Ready​
AVC​
MP4​
20000 Hours​
Button Control​
App​
Wireless​
6 watts​
15 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount/Ceiling Mount/Floor Mount/Tripod Mount​
4.57"L x 4.53"W x 1.38"H​
3.78"L x 3.38"W x 1.14"H​
Setting up this projector was a breeze; it was intuitive and hassle-free right out of the box. I was pleasantly surprised by how easy it was to get it running, which is something I've struggled with in the past with other projectors. However, I did encounter some challenges regarding connectivity, particularly with the need for specific HDMI adapters to connect my phone or other devices. While I managed to get everything working with the right cables, it's worth noting that the projector doesn’t support Bluetooth or the Kodak Luma app, which could be a drawback for some users.
Setting up the device was straightforward, though I did notice it requires a brief reset before initial use. Once that was out of the way, everything operated smoothly. The simplicity of the setup process makes it accessible for users of all tech levels, which I appreciate.
Setting up the projector was a breeze thanks to its user-friendly interface. I appreciated how quickly I could connect it to various devices, including smartphones, laptops, and streaming sticks, via HDMI, USB, and Bluetooth. The intuitive controls made the whole process straightforward, allowing me to be ready to project within minutes. I particularly enjoyed the versatility it offered, accommodating different media formats and connection methods, which is essential for a device intended for both casual and professional use.
• Compact and portable design
• Solid build quality feels premium
• Easy to set up and use
• Good image quality in dark environments
• Sufficient battery life for short-duration use
• Battery life is underwhelming for extended use
• Requires specific adapters for device connectivity
• Image brightness could be better for entertainment purposes
• Occasional discoloration in projections
• Focus adjustment is tricky due to design
Overall, the Kodak Ultra Mini Portable Projector is an impressive little gadget that does a commendable job for its intended purposes, especially in art-related projects and casual viewing. While it does have its limitations, particularly regarding battery life and brightness, the projector excels in portability and ease of use. It's a worthwhile investment for those needing a compact and reliable projector for short presentations or creative endeavors, though I would advise potential buyers to consider their specific needs to ensure it aligns with those expectations.
• Compact and portable size
• Excellent brightness and clarity
• Simple setup process
• Affordable price
• Requires a reset before first use
Overall, I am thoroughly impressed with this tiny device. Its portability, combined with a remarkable viewing experience and reasonable pricing, makes it a fantastic option for anyone looking for convenience while traveling. I highly recommend it to others seeking a reliable and easy-to-use gadget!
• Impressive image quality with vibrant colors
• Good battery life lasting up to 3 hours
• Versatile connectivity options (HDMI, USB, Bluetooth)
• Built-in screen mirroring capability
• Requires frequent focusing during initial use
• Built-in speaker lacks volume and quality
• Limited to no access to certain streaming apps without additional devices
• Occasional connectivity issues with AirPlay
• Must be manually powered on, remote control needs line-of-sight
The TMY Ultra Mini Projector has proven to be a fantastic addition to my tech collection. It combines portability, ease of use, and impressive image quality into one compact package, making it a versatile option for both personal entertainment and professional presentations. While there are some minor drawbacks, such as the speaker quality and the need for occasional focusing, these do not detract from the overall performance. For anyone seeking a reliable and powerful portable projector, I wholeheartedly recommend this device.
Astro51450
The Kodak Ultra Mini Portable Projector is awesome! It gives super sharp images, which makes it perfect for tracing my drawings. Totally worth the money!
JavierMnS
The Kodak Ultra Mini Portable Projector is super tiny! The resolution isn’t great and it’s not super bright, but who cares? I got a USBC to HDMI cable for my phone, so I can watch movies and shows anywhere! It’s my new favorite gadget—wish I could give it six stars!
horizon936
I love the EZCast J4 Projector! It's super tiny and super bright! Super easy to use and perfect for travel. Totally recommend it!
AwesomenessDjD
EZCast J4 Projector: Super portable! It's so small you can hold it in one hand. The picture is clear and bright, and the price is just right! Just take a minute to reset before using, and you're good to go!
Curtis_Baefield
I got the TMY Ultra Mini Projector for my daughter to watch cartoons in my room since I don't have a TV, but I've ended up using it way more! Love that I can mirror my phone and watch Netflix and sports on it. The picture is super clear too. Seriously, just buy it!
pricelesslambo
Check out the TMY Ultra Mini Projector! Super portable and perfect for camping—I'm using it with my Steam Deck. Plus, it’s got Type-C charging, which is pretty cool!
