Harry Williams
- 1 Specs
- 2 Which to get
When it comes to portable projectors, the KODAK Luma 350 and the PANSEBA Mini Projector each offer distinct features that cater to different user needs, but which one truly deserves your investment? The KODAK Luma 350 stands out with its DLP technology, promising vibrant colors and the capability to project massive images of up to 150 inches. It’s designed for seamless compatibility with all smart devices, making it a versatile choice for both casual and tech-savvy users.
On the other hand, the PANSEBA Mini Projector claims to deliver a brighter and clearer image, boasting a 50% increase in brightness compared to other mini projectors. Its upgraded Bluetooth capabilities allow it to double as a speaker, adding an extra layer of functionality that could appeal to those who prioritize audio quality in their viewing experience.
In this comparison, we’ll dig deeper into what each projector brings to the table, the real-world performance of their features, and help you decide which one might be the better fit for your home cinema or on-the-go entertainment needs. Let’s break down the specs, usability, and practical differences between these two contenders.
The KODAK Luma 350 boasts DLP projection tech, promising HD video with vibrant colors and brightness. It can project up to 150 inches and has a companion app for easy wireless control. But the remote only turns off the projector—kinda limiting, right?
On the flip side, the PANSEBA Mini Projector promises brighter images with an impressive contrast ratio and supports 1080p resolution. Plus, it has built-in HIFI speakers and two-way Bluetooth, so it can also double as a speaker. Sounds great, but I wonder if the sound quality holds up compared to the KODAK.
Anyone have experience with either of these? Which one do you think delivers better overall value?
Specs
Parameter | KODAK Luma 350 Portable Projector | PANSEBA Mini Projector Home Projector |
Reference Price | $309.99 | $59.99 |
Recommended Uses | Indoor/Outdoor | Home Cinema |
Built-In Media | Kodak Luma 350 Projector, Carrying Travel Case, 6FT HDMI Cable | User Manual, Power Cord, Projector Screen, Remote, HDMI Cable |
Highlight | Bundle Items Include: Kodak Luma 350 & 6FT HDMI Cable THE PREMIER CHOICE FOR DLP PROJECTION | Portable Smart Projector Utilizes Breakthrough Digital Light Processing Technology to Render HD Video & Imaging w/ Stunning Color, Clarity &LED-Lumen Brightness | Massive Displays Up to 150” | Use With the iOS Luma 350 App for Intuitive Wireless Access COMPATIBILITY ACROSS ALL SMART DEVICES | Turn Your Phone Into a Remote| Discover the Ultimate All-Inclusive Multimedia Experience w/ Onboard Wi-Fi, Bluetooth, Screen Mirroring, HDMI & USB for Phone, Laptop, Tablet, Streaming through downloaded Apps, Blu-Ray, Consoles & More. Note: The remote can only turn off the projector. | 【Upgraded Two-way Bluetooth 5.2 & HIFI Speaker】Built-in powerful speakers, this portable bluetooth projector provides HIFI sound effect while watching movie in a Max 200 inches screen. The updated Two-way Bluetooth function is not only supported to connect with your bluetooth speaker wirelessly, but also you can use this mini projector as a bluetooth speaker to listen music from your phone. Enlarge your happiness with our Bluetooth projector, just enjoy it! 【50% Brighter Images than Similar Projectors 】2025 Upgraded mini projector equipped with 8000:1 contrast ratio, supported 1080p resolution, brings you a 50% brighter images than similar projectors in market. It provides you with a premium home cinema experience with the bigger screen and clearer image. 【50% More Clear Images than Similar Projectors 】2025 Upgraded Chips make this movie projector more clear than other similar projectors. Our technical department researched and upgraded the chip to improve the clarity of the picture, so you can enjoy the movie everywhere and anytime. |
Screen Size | N/A - 1.5E+2 Inches | 32 Inches - 200 Inches |
Throw Distance | N/A - 18.9 Feet | 2.65 Feet - 26.25 Feet |
Contrast Ratio | 3500:1 | 8000:1 |
Maximum Resolution | 854 x 480 Pixels | 1980 x 1080 Pixels |
Native Resolution | 854 x 480 | 1920 x 1080 |
Brightness | 200 lumen | 95 Lumen |
Display Type | DLP | LED |
Picture Enhancement | DLP | High Contrast Ratio and Full HD Resolution |
Other Features | Built-In Speaker, Portable, Built-In Wi-Fi | Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom |
Video Encoding | AVC | H.264 or MPEG-4 AVC |
LightSource Life | 30000 Hours | 50000 Hours |
Controller Type | Remote Control | Remote Control |
Control Method | App, Remote, Touch | Remote |
Connectivity Technology | USB | Bluetooth, USB, HDMI, 3.5mm Jack |
Compatible Devices | Laptop, Gaming Console, Tablet, Smartphone | TV Stick, Smartphone, USB, SD Card |
Wattage | - | 55 watts |
Mount Type | Wall Mount | Ceiling/Floor/Tabletop/Tripod/Wall Mount |
L x W x H | 3"L x 2"W x 2"H | 7.28"L x 5.98"W x 2.95"H |
Which to get
Looking to buy a portable projector and I'm torn between the KODAK Luma 350 and the PANSEBA Mini Projector. Both seem solid, but I want to get the scoop on picture quality, sound quality, system compatibility, and any potential downsides.The KODAK Luma 350 boasts DLP projection tech, promising HD video with vibrant colors and brightness. It can project up to 150 inches and has a companion app for easy wireless control. But the remote only turns off the projector—kinda limiting, right?
