JMGO PicoFlix vs XGIMI MoGo 2 Pro vs MoGo 3 Pro: A Comprehensive Decision Guide for Portable Projectors
cruets620
JMGO PicoFlix​
XGIMI MoGo 2 Pro​
XGIMI MoGo 3 Pro​
Price​
$499
$399.99
$449.99
Home Cinema​
Education, Outdoor, Home Cinema, Camping, Gaming, Business​
Visual Quality: 420 ISO Lumens brightness, HDR10 support, 1080P FHD resolution, 124% Rec.709 color gamut, 400:1 FOFO contrast ratio.
Portability: 150-inch Blu-ray 3D screen, 10,000mAh battery, up to 4.5 hours movie time (eco mode), lightweight and easy to carry.
Smart Features: Netflix on Google TV, access to 10,000+ apps, 800+ free channels, Google Assistant AI, built-in Google Cast.
Viewing Flexibility: Integrated gimbal for projection at any angle, real-time auto screen correction for sharp images.
Audio Experience: Built-in 10W dual speakers, Dolby Audio, Bluetooth speaker functionality.​
Flexible Casting Combination: 120ยฐ adjustable stand, compact design for versatile entertainment.
Remarkable Lifelike Vision: 400 ISO lumens, D65 color temperature, 90% DCI-P3 color gamut for vibrant colors.
The Ultimate Portable Solution: Weighs 3.5 lb, multi-angle stand, easy to carry for professional visual and sound experience.
Intelligent Screen Adaption Technology: ISA 2.0 with 3D ToF and CMOS for automatic keystone correction and autofocus.
Non-stop Entertainment: Android TV 11.0 access, support for streaming platforms like Netflix.​
Streaming Capability: Google TV, Netflix, 10,000+ apps, 800+ free channels
Bluetooth Connectivity: Automatic firmware updates for enhanced connectivity
Design Features: 130ยฐ built-in stand, ISA 2.0 for auto-adjusted image, metal slide rail for stability and lens protection
Power Options: Connect to Type-C 65W power bank for portable entertainment
Input Ports: Multiple for seamless connectivity
Image Quality: 450 ISO Lumens brightness, 90% DCI-P3 color gamut, 1080P resolution, screens up to 120 inches​
Side-by-Side Comparison​
JMGO PicoFlix​
XGIMI MoGo 2 Pro​
XGIMI MoGo 3 Pro​
60 Inches - 150 Inches​
40 Inches - 200 Inches​
1 Meters - 4 Meters​
1 Meters - 6 Meters​
1.06 Meters - 5.3 Meters​
400:1​
1000:1 or higher​
Display Resolution​
1920 x 1080 Pixels​
1920 x 1080 Pixels​
1920 x 1080 Pixels​
420 Lumen​
400 Lumen​
450 Lumen​
DLP​
DLP​
DLP​
Picture Quality Enhancement​
HDR10​
HDR 10​
4-point Keystone Correction( Vertical and Horizontal), ISA 2.0 uninterrupted auto focus, HDR 10, Intelligent Screen Alignment Intelligent Obstacle Avoidance, ISA 2.0 uninterrupted auto keystone​
JMGO PicoFlix​
XGIMI MoGo 2 Pro​
XGIMI MoGo 3 Pro​
H.264 or H.265​
AVC​
Light Source Life​
25000 Hours​
25000 Hours​
Button Control, Voice Control​
App, Remote, Voice​
Remote, Touch​
Remote, Touch​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Tabletop Mount​
Noteworthy Features​
Gimbal Auto Real-time Image Correction : Auto Focus / Auto Keystone Correction, ๐†๐จ๐ญ ๐ช๐ฎ๐ž๐ฌ๐ญ๐ข๐จ๐ง๐ฌ ๐š๐›๐จ๐ฎ๐ญ ๐ฉ๐ซ๐ข๐œ๐ข๐ง๐ ? ๐๐ฅ๐ž๐š๐ฌ๐ž ๐œ๐จ๐ง๐ญ๐š๐œ๐ญ ๐—๐— ๐—š๐—ข ๐—–๐ฎ๐ฌ๐ญ๐จ๐ฆ๐ž๐ซ ๐—ฆ๐ฎ๐ฉ๐ฉ๐จ๐ซ๐ญ., 10000mAh Built-in Battery with 4.5H of Playtime (ECO Mode) / Type-C / Portable Mini / Outdoor, DLP / 1080P FHD / 420 ISO Lumens / 150 Inch Big Screen / HDR10 / Blu-ray 3D / 10W Dual Speakers / DD+, Google TV / Netflix (Official Licensed) / Wifi and Bluetooth / Smart​
Built-In Speaker, Auto Obstacle Avoidance, High Light Transmission Coated Lens, Intelligent Eye Protection, 4-point Keystone Correction( Vertical and Horizontal), ISA 2.0 uninterrupted Auto Keystone, Auto Screen Alignment, Auto Focus​
Built-In Speaker, Built-In Netflix, Advanced Eye Protection, Intelligent Screen Alignment, Auto Focus in Seconds, Uninterrupted Auto Keystone Correction, Intelligent Obstacle Avoidance, Build-In Adjustable Stand, 450 ISO Lumens​
Connectivity​
JMGO PicoFlix​
XGIMI MoGo 2 Pro​
XGIMI MoGo 3 Pro​
Wi-Fi​
Bluetooth, Wi-Fi, USB, HDMI​
Bluetooth, USB​
Hardware Connectivity​
USB Type C, USB, HDMI​
USB Type C, USB 2.0 Type A, HDMI, 3.5mm Audio, 802.11 ac/b/g/n, Bluetooth 5​
USB Type C, Micro-HDMI, USB 2.0​
Laptop, Smartphone, Gaming Console, Media Player​
Tablet​
Laptop, Smartphone, Gaming Console​
Measurements​
JMGO PicoFlix​
XGIMI MoGo 2 Pro​
XGIMI MoGo 3 Pro​
Dimensions L x W x H​
9.15"L x 3.15"W x 3.15"H​
7.56"L x 6.06"W x 5.2"H​
3.74"L x 3.74"W x 8.06"H​
Item Weight​
3.3 Pounds​
3.53 Pounds​
1.1 Kilograms​
Product
PROS AND CONS​
JMGO PicoFlix​
Pros
โ€ข Portable size and lightweight design, easy to carry
โ€ข Built-in battery lasts around 180 minutes, suitable for full-length movies
โ€ข Gimbal design allows for flexible projection angles
โ€ข Real-time image correction for hassle-free setup
โ€ข Vibrant colors and solid picture quality in low-light environments
โ€ข Google Cast integration works seamlessly
โ€ข Remote includes shortcuts for Netflix and YouTube
โ€ข Sturdy and premium feel from well-designed packaging
Cons
โ€ข Brightness at 450 lumens is best suited for darker spaces
โ€ข Built-in speakers are decent but not exceptional, external speakers recommended
โ€ข Picture quality may not satisfy those looking for high-end projector performance
โ€ข Battery life may limit usage for extended viewing sessions without recharge
XGIMI MoGo 2 Pro​
Pros
โ€ข Super cool design
โ€ข Easy to set up
โ€ข Compact size
โ€ข Amazing picture quality
โ€ข Smooth performance
โ€ข Bright display
โ€ข Loud sound
โ€ข Portable
โ€ข Good for gaming
โ€ข Smart and intuitive interface
Cons
โ€ข Leaves a massive backlight around the video after autofocus
โ€ข No built-in Netflix; requires third-party app for access
โ€ข Best performance requires a dark room
โ€ข Multiple passwords needed for Android TV access
XGIMI MoGo 3 Pro​
โ€ข Great, compact design
โ€ข Sturdy and thoughtful hardware
โ€ข Huge screen and long focal length
โ€ข Automatic Keystone and Focus
โ€ข Advanced settings for personalized setup
โ€ข Google TV is fast and easy to use
โ€ข Excellent speakers for a small design
โ€ข Impressive brightness, even in some daylight
โ€ข No built-in battery (requires additional purchase of power base)
โ€ข Mini HDMI requires an adapter for direct connection
โ€ข Bluetooth audio drops frequently
โ€ข Lack of headphone jack complicates external audio connection
โ€ข Laggy or sporadically unresponsive remote
