Elena
Earlier this year, JMGO release JMGO O1, and it drew a lot of interest. Now, let's see the new product JMGO O1 Pro review, is it better than JMGO O1.
JMGO together with optical master Leica redesigned the O1 Pro's light path, optimizing the throw ratio to 0.21:1, you can project a 100-inch large screen in 23cm from the wall, the distance is only one-tenth of the traditional long-throw projectors. As for the lens, the camera uses 12 F1.7 large aperture lenses, including four aspherical lenses and one ED lens, to further ensure the image effect.
Of course, the reflective ultra-short-throw is also more demanding on technology, but in the joint efforts of JMGO and Leica, O1 Pro solved the common problems of short-focus projection, not only to control the screen distortion below 0.5 (traditional telephoto projection generally 1 to 2%), while significantly improving the noise reduction performance, clarity and dynamic contrast ratio and other core parameters.
JMGO O1 Pro adds a front AI camera, so it also realizes a more powerful intelligent perception system. Not only does it support automatic brightness adjustment and wall color calibration, but it also innovatively adds gesture recognition to create a new way of interaction.
In classic mode, users can adjust the volume, pause/play and other operations by making corresponding gestures on the front of the body, and the recognition is accurate and responsive. Compared to the traditional remote control, voice control, gesture recognition is more convenient, while the sense of technology
Wall color calibration is also a very useful feature, as the projector is able to calculate the most desirable color effect in its current state by using the color temperature sensor. When color calibration is turned on, the machine will automatically make adjustments to present the most suitable picture in a short period of time. Therefore, you will get a good picture although your wall isn't white.
It is also worth mentioning the zero perception screen extreme correction, a feature that combines sensorless autofocus with automatic keystone correction. The projector stays square and clear right after power on and there are no other images such as assisted focus during viewing, just as convenient as using a traditional LCD TV.
JMGO O1 Pro continues the classic and companion dual-mode configuration, you can open a new world of light and shadow with one click through the Luna key on the remote control. Compared with its predecessor, the companion mode is richer, and the design concept based on the borderless UI gives a new meaning to the wall.
1. Together with optical masters, JMGO O1 Pro reinvents light and shadow
2. Five-dimensional intelligent perception to create a new way of interaction
3. New companionship model to create a quality life
