Is Viewsonic R3 projector suitable for home use? New 1080P high quality portable projector released
Adney
Viewsonic has announced the launch of a 1080p full HD smart portable LED projector, Viewsonic R3 projector. Viewsonic R3 projector is portable, with more than 100%Rec.709 color gamut coverage and 1920x1080 full HD resolution. So is Viewsonic R3 projector good? Let's take a look at it.
1. Display parameters
Viewsonic USB R3 projector optical machine built-in 0.23DMD display chip, through Texas Instruments chip jitter technology, the resolution of the jitter to 1920x1080 full HD resolution, display full HD high-quality picture; Brightness, LED light source brightness 600 lumens, light source life up to 20,000 hours.
2. Appearance parameters
Viewsonic R3 projector adopts coral green matching color, the color design is very fashionable. The weight of the body is only 0.71kg, the product size is 228*121*35mm, it's a very portable design. Viewsonic R3 can be contained in the backpack, easy to travel, can be used at home and is also suitable for business scene.
3. Performance parameters
This new Viewsonic R3 projector adds new technology, equipped with TOF laser +CMOS camera, support for laser autofocus, moving the projector can trigger the projector to auto-focus. Trapezoidal correction, thanks to the improvement of algorithm and detection technology, supports up and down left and right plus or minus 30 degrees of automatic trapezoidal correction. Built-in 9000mAh battery for 1.5 hours of battery life.
4. Interface parameters
In terms of ports, it has a 3.5mm audio port, dual USB2.0 ports, an HDMI, a LAN and A DC power port. The variety of interfaces is quite rich, fully meet the needs of home and business.
5. System parameters
The system has built-in Tencent Aurora, covering the entire network resources of Tencent Video; The hardware configuration uses an AmlogicT972 processor, 4GB of running memory, and 32GB of storage space. Tencent Video with single system resources is obviously not enough, but you can install Dangbei market to download more online video apps; The 32GB storage space is large enough to install multiple TV applications
