iPad air5 vs air4: what's the difference?
KL111
When iPad air5 vs air4, what's the difference? There are 3 main differences between iPad air5 and air4.
1. Configuration difference
The biggest difference between ipadair5 and air4 is the processor. The ipad air 5 uses the same M1 processor as the ipad pro, which not only increases support for 5G, but also greatly improves the performance compared to the A1, with a performance improvement of about 58%.
2. RAM Difference
While the processor was upgraded, the iPad air 5 also ushered in an upgrade in terms of storage. It's upgraded from 4GB of RAM in the iPad Air 4 to 8GB of RAM, which is the same RAM configuration as the regular version of the M1 iPad Pro.
3. Camera difference
The iPad Air 5 has ushered in an upgrade in photography, and the most obvious upgrade is the front camera. The iPad Air 5 has been upgraded from the original 7-megapixel front-facing lens of the iPad Air 4 to the current 12-megapixel ultra-wide-angle lens, and supports 2x zoom + character centering function, which is consistent with the iPad mini 6 configurations. The rear camera is not much different except that the iPad Air5 adds support for an extended dynamic range for video capture up to 30 fps.
