windstri85
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 System
- 2.2 Display
- 2.3 Audio
- 2.4 Connectivity
- 2.5 Features
- 2.6 Measurements
- 3 Conclusion
Parameter | INSIGNIA F20 | INSIGNIA F30 |
Price | $89.99 | $219.99 |
Model Year | 2022 | 2023 |
Specific Uses | - | Home Viewing |
Highlight | Display Size: 32-inch Resolution: 720p Refresh Rate: 60Hz Smart TV Platform: Fire TV Streaming Access: Over 1 million movies, TV shows, and channels Voice Control: Alexa Voice Remote Connectivity Options: Wi-Fi, Ethernet, HDMI, USB, Apple AirPlay Audio Output: Optical digital audio output | Display Size: 50 inches Resolution: 4K Ultra HD (2160p) Smart TV Features: Access to over 1 million streaming movies, TV shows, and channels via Fire TV Supported Streaming Services: Apple TV+, Disney+, Hulu, Netflix, Prime Video Voice Control: Alexa voice commands via remote or Echo device Audio Technology: DTS Studio Sound with two-speaker playback |
System
Operating System | Fire TV | FireOS |
Internet Applications | Netflix, Apple TV+, Prime Video, Disney+, Hulu, Sling TV, YouTube, HBO Max, Spotify, Peacock, ESPN+ | Disney Plus, HBO Max, Netflix, Prime Video, Pandora, Hulu, Paramount+, Sling TV, ESPN+, Apple TV, YouTube |
Remote Control | Voice control, Standard | Voice Control |
Controller Type | Amazon Alexa | Remote Control |
Aspect Ratio | - | - |
Display Technology | LED | LED |
Screen Finish | Flat | Flat |
Resolution | 720p | 4K |
Response Time | - | - |
HDR Format Supported | - | HDR10 |
Maximum Display Brightness | - | - |
Display Backlight | - | LED |
Display Backlight Setting | - | - |
Picture Quality Enhancement | - | - |
Motion Enhancement | - | - |
Audio
Number of Audio Channels | - | - |
Audio Output Mode | Digital | Digital |
Audio Input | HDMI | HDMI |
Speaker Description | - | Built-In Speakers |
Connectivity
Connectivity Technology | Wi-Fi 5 (802.11ac) | Wi-Fi, Wi-Fi 5 (802.11ac) |
Bluetooth Version | - | - |
Screen Mirroring | - | AirPlay, Miracast |
Total Usb Ports | 1 | 1 |
Number of HDMI Ports | 3 | 3 |
Connector Type | - | HDMI, USB |
Signal Format | - | Digital |
Video Encoding | - | - |
Compatible Devices | - | Home Theater System, Set-Top Box, Gaming Console, Satellite Box, DVD Player, Streaming Device, Blu-Ray Player, Cable Box |
Tuner Type | ATSC,Digital | ATSC, Clear QAM |
Noteworthy Features | Screen Mirroring | Flat |
Measurements
Dimensions D x W x H | 8.3"D x 28.9"W x 19"H | 10.4"D x 44.4"W x 27.8"H |
Item Weight | - | - |
Screen Size | 32 Inches | 50 Inches |
Product | PROS AND CONS |
INSIGNIA F20 | Pros • Very easy setup and installation • Smart TV functionality with Fire TV integration • Excellent picture quality • Multiple HDMI inputs for additional devices • Access to a wide range of apps, including Vudu • Smooth performance when switching between apps and inputs • Good value for the price Cons • TV stands located at the edges, requiring ample table space for support • Initial difficulty in typing passwords using the remote • Some minor film grain noticed in certain content Overall Impression The TV is a fantastic addition to any kitchen or workspace, offering excellent picture quality and a seamless smart TV experience with Fire TV. It addresses the user's needs for app accessibility and HDMI inputs effectively. While the edge stand design poses a slight challenge for placement, the overall performance and value make it a highly recommended choice. |
INSIGNIA F30 | Pros: • Price • Sound/picture quality • Ease of setup • Settings/user preferences are easily customizable • Connects to book apps for audiobooks and reading Cons: • White lines appear on the left side of the screen after extended use • Remote quick app buttons are not customizable • Bulky/deep design may not be ideal for small spaces Overall Impression: This TV is a solid choice for those looking for an affordable option with good sound and picture quality. Its ease of setup and customization options make it user-friendly, while the integration with book apps adds a unique touch for family activities. However, potential buyers should be aware of the screen issue after prolonged use and the remote's limitations. Overall, it's recommended for casual users who value functionality over high-end features. |
