InFocus IN126STa vs Alwtniet Ultra Short Throw Projector: Which Delivers Better Brightness and Smart Features for Your Space?
KeyGood5298
  1. 1 Specs
  2. 2 Which to get
In the world of projectors, the struggle between short throw and ultra short throw technology often sparks debate among enthusiasts. Today, we're diving into a head-to-head comparison of the InFocus IN126STa and the Alwtniet Ultra Short Throw Smart Projector.
The InFocus IN126STa, with its WXGA resolution and impressive 3300 lumens, promises bright and clear images, making it a strong contender for those who prioritize brightness and connectivity options. Its short throw lens allows for a larger image from a closer distance, ideally suited for smaller spaces.
On the other hand, the Alwtniet HY450 claims to elevate the viewing experience with native 1080P resolution and advanced offset technology, offering flexibility in placement thanks to its ultra short throw capabilities. With features like electric focus and auto keystone correction, it seems designed for users who want convenience without sacrificing quality.
So, which one truly delivers? Is it the tried-and-true brightness of the InFocus or the modern convenience and resolution of the Alwtniet? Let’s break down the details and see which projector stands out in the battle for your home theater setup.
Specs​
InFocus IN126STa Short Throw Projector​
Alwtniet Ultra Short Throw Smart Projector Projector​
$976​
$139.99​
Indoor/Outdoor​
Adaptor, User Manual, Remote​
WXGA (1280 x 800) native resolution
Short throw lens (0.48 throw ratio), 3300 lumens of brightness
Connections: VGA (2), HDMI, USB-A, USB-B, USB mini, RS-232, S-Video, RCA
Native 1080P & 700 ANSI: With its superior 1080P physical resolution and 700 ANSI, Alwtniet HY450 projector delivers vivid and clear images on a large 200 inches screen, allowing you to experience theater-quality stunning visuals at home
Advanced Offset Technology and Ultra-short Throw Ratio: HY450 smart projector is equipped with 75% auto offset technology and impressive 0.6:1 projection ratio, supports you to project a large image in a small space, giving you flexible placement option
Electric Focus & Auto Keystone Correction: HY450 video projector is equipped with Electric Focus and Vertical Keystone Correction, makes it easy to achieve the perfect projection without cumbersome manual setup, give you an immersive experience
1500 Pixels - 762 Centimeters​
N/A - 2E+2 Inches​
0.55 - 2.1 Meters​
15000:1​
1280 x 800​
7680×4320​
1280 x 800​
700 lumen​
LED​
3D-ready, short_throw​
Auto Offset; 0.6:1 Ultra Short Throw Ratio; WIFI6; BT5.4; Automatic Vertical Correction; Electric Foucs; 200 Inch Projection Size; 4K Supported; 700 ANSI Brightness; 2+32GB Memory; Android 11 OS​
HEVC Main 10​
240 Watts​
Button Control​
HDMI
Wi-Fi​
Laptop, Gaming Console, Tablet, Smartphone​
2 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
11.61"L x 5.79"W x 5.71"H​
Which to get​
Looking to upgrade my home setup and I'm torn between these two projectors—InFocus IN126STa and Alwtniet Ultra Short Throw Smart Projector.
First off, picture quality: the InFocus has a WXGA resolution (1280 x 800) and 3300 lumens, which sounds solid for brightness, especially in well-lit rooms. But the Alwtniet boasts a native 1080P resolution and claims to deliver vivid images with its 700 ANSI lumens. I’m curious if that 1080P really makes a noticeable difference in clarity, especially on larger screens.
When it comes to sound quality, I didn't see much on that front in the descriptions. Does anyone know if one of these projectors has better built-in speakers or sound options? I really want something that can fill the room without needing to hook up extra speakers right away.
In terms of system and features, the Alwtniet seems to have some cool tech with its electric focus and auto keystone correction, which sounds super convenient. The InFocus seems more straightforward but has a variety of connection options, which might be useful for future-proofing.
Lastly, I’m a bit worried about potential downsides. Any issues with overheating, noise levels, or setup hassles with either? Would love to hear your thoughts or experiences with either of these projectors before I pull the trigger!
