I'm considering the Paris Rhône 4K UHD UST Laser Projector and the VividStorm S Pro screen.
sai
Hello,
I'm considering the Paris Rhône 4K UHD UST Laser Projector and the VividStorm S Pro screen for my home theater setup.
Since my room has a lot of Windows,the choice of the screen is crucial,
especially considering the presence of windows and the need for good color contrast during daylight.
Ambient Light Rejection:
The VividStorm S Pro screen is known for its ambient light rejection technology.
This feature helps maintain good color contrast even in well-lit rooms.
I want to make sure to check the specs and user reviews to make sure it meets my requirements.
Screen Size and Placement:
Choose a screen size that fits well in my room and complements the capabilities of the Paris Rhône projector.
The distance and angle of the projector to the screen also play a role in the overall viewing experience.
Thank you very much!
EmmaEvans
If your room has a lot of windows, you are right to choose this screen. I was worried about this problem before buying it, but after receiving the screen, the effect is great.
