How to Turn Off LG Smart TV Speakers: A Step-by-Step Guide
If you’ve recently purchased an LG Smart TV or have been using one for a while, you might have encountered situations where you want to turn off the TV’s built-in speakers. Whether you’re connecting external speakers or using a soundbar, turning off your LG Smart TV’s internal speakers can improve your audio experience by avoiding sound interference or echo.
In this comprehensive guide, we will walk you through the easy steps to turn off the built-in speakers on an LG Smart TV and ensure that you get the best audio setup for your home entertainment.
Why Turn Off LG Smart TV Speakers?​
There are several reasons why you might want to turn off the internal speakers of your LG Smart TV:
  • External Audio Devices: If you're connecting your TV to external speakers, a soundbar, or a home theater system, you might want to turn off the TV’s built-in speakers to avoid conflicting audio.
  • Better Sound Quality: Many external audio devices provide superior sound quality compared to built-in TV speakers.
  • Avoid Echo or Audio Delay: Using both internal and external speakers at the same time can create an echo effect or a delay between the two sound sources.
Turning off the built-in speakers can streamline your audio experience and ensure that you get the best sound possible.
How to Turn Off LG Smart TV Speakers: Step-by-Step Instructions​
Follow these simple steps to disable the built-in speakers on your LG Smart TV and set up an external audio device:
Step 1: Open Settings Menu​
  1. Turn on your LG Smart TV and make sure it's connected to the internet.
  2. Press the "Settings" buttonon your LG remote control to open the settings menu.
    • Alternatively, you can press the "Home" button, navigate to "Settings", and then select "All Settings".
Step 2: Go to Sound Settings​
  1. In the settings menu, scroll down and select "Sound". This will open the sound-related settings of your TV.
  2. Look for the "Sound Out" option, which controls where the audio output is sent (TV speakers, external speakers, etc.).
Step 3: Select External Sound Output​
  1. Under "Sound Out", select "External Speakers", "HDMI ARC", or "Optical"depending on how you are connecting your external audio device.
    • If you are using a Bluetooth speaker or soundbar, you should choose "Bluetooth" or "LG Sound Sync".
  2. When you select an external output, the built-in TV speakers will automatically be turned off.
Step 4: Adjust Audio Settings (Optional)​
  • You can also adjust additional sound settings, such as sound mode (Standard, Cinema, Music, etc.), equalizer settings, and volume level to optimize the audio from your external device.
  • If you notice that your external speakers are not syncing well with the TV’s audio, you may want to adjust the audio delay settings under the sound menu.
Alternative Method: Turning Off TV Speakers Using Audio Settings​
For some LG Smart TV models, the process may slightly vary. If the above steps do not work, try this alternative method:
  1. Go to Settings > Sound > Sound Out.
  2. Choose the desired external sound option (HDMI ARC, Optical, Bluetooth, etc.).
  3. Ensure the TV Speaker option is set to Off.
  4. If you are using Bluetooth speakers or a soundbar, make sure the device is paired and properly connected.
How to Turn Off LG Smart TV Speakers for Specific Apps​
Sometimes, apps on your TV (such as YouTube or Netflix) may have their own audio settings. If you want to turn off TV speakers while using a specific app, follow these steps:
  1. Open the app (e.g., YouTube or Netflix).
  2. Go to the audio settings within the app and look for a "sound output" or "audio settings" option.
  3. Choose the external speakers option if available, and ensure that TV speakers are turned off in the app’s settings.
FAQs: Turning Off LG Smart TV Speakers​
1. Can I use a Bluetooth soundbar and keep the TV speakers off?​
Yes, you can easily connect a Bluetooth soundbar to your LG Smart TV and turn off the internal speakers. Just follow the steps above to select Bluetooth as the sound output and the TV’s built-in speakers will automatically turn off.
2. Why am I still hearing sound from my TV speakers even after selecting external sound?​
If the TV speakers are still active, double-check that the external audio device is properly connected and turned on. If the connection is correct, the sound should automatically come from the external device.
3. How do I turn the sound back on for the TV?​
To enable the TV’s internal speakers again, go back to the Sound Out settings and select "TV Speakers" or "Internal Speaker" as the output option.
4. Can I control the volume of external speakers through the LG TV remote?​
Yes, if you have connected an external audio device via Bluetooth or HDMI ARC, you should be able to control the volume using your LG TV remote, depending on the device and connection type.
Turning off the LG Smart TV speakers is a simple yet effective way to enhance your audio experience when using external sound systems like soundbars, home theater systems, or Bluetooth speakers. By following the steps outlined above, you can easily disable the built-in speakers and enjoy a more immersive viewing experience.
If you found this guide helpful, feel free to share it with others who are looking for a similar solution!
