How to Sync Roku Remote to TV? Guide for All Remote Types
Looking to sync your Roku remote to your TV but not sure where to start? Whether you’re setting up a brand-new device or reconnecting a remote that’s stopped working, this guide will walk you through step-by-step instructions to get your Roku remote synced to your TV—fast.
We’ll cover both standard IR Roku remotes and enhanced voice remotes so no matter your setup, you’ll be back to streaming in no time.
Which Roku Remote Do You Have?​
Before syncing, it’s important to know which type of Roku remote you're using:
  • Standard IR Remote (Infrared): Points directly at the TV.
  • Enhanced “Point Anywhere” Remote: Connects via Wi-Fi or Bluetooth and works even if not pointed at the TV.
  • Voice Remote Pro or Remote with Pairing Button: Has advanced features like voice control, TV power, and volume buttons.
The syncing process varies, so let’s break it down by remote type.
How to Sync a Standard Roku IR Remote to Your TV​
This type of remote doesn’t require a pairing process with the Roku device—it works automatically as long as there’s a clear line of sight.
  1. Insert fresh batteries into the remote.
  2. Make sure your Roku device is powered on and connected to your TV.
  3. Point the remote directly at the Roku player or TV and press any button.
  4. If it doesn’t respond, re-seat the batteries and ensure nothing is blocking the IR signal.
📌 Note: These remotes only control the Roku device—not your TV’s power or volume.
How to Sync Roku Enhanced Remote to TV (With Pairing Button)​
If you have a Roku Voice Remote, Voice Remote Pro, or another enhanced remote with a pairing button, follow these steps:
  1. Turn on your TV and Roku device.
  2. Remove the battery cover and locate the pairing button (usually near the batteries).
  3. Press and hold the pairing button for about 5 seconds until the status light starts blinking.
  4. Wait for the “Remote pairing” message to appear on your screen.
  5. Once the pairing is complete, test the remote’s navigation, volume, and power buttons.
💡 If nothing happens, restart your Roku device and try again.
Re-Pairing a Roku Remote That Lost Connection​
Sometimes your remote can lose sync after a firmware update or power interruption.
  • Unplug the Roku device for 10 seconds, then plug it back in.
  • Wait until the home screen loads.
  • Press and hold the pairing button on your remote until the LED blinks.
  • Pairing should complete within 30 seconds.
How to Program Roku Remote to Control TV Power and Volume​
If you’re using an enhanced remote with TV controls, Roku makes it easy to program those buttons.
Here’s how:​
  1. Go to Settings > Remotes & Devices > Remotes > Set up remote for TV control.
  2. Follow the on-screen prompts.
  3. Roku will play music and ask if you hear it—this helps identify your TV brand.
  4. Confirm when the music stops playing.
Now your Roku remote can control TV power, volume, and mute.
Troubleshooting Roku Remote Sync Issues​
Here are common fixes if syncing fails:
IssueFix
Remote not respondingReplace batteries, restart Roku device
Pairing light not blinkingTry a different set of batteries
No “pairing screen” appearsRestart both the remote and Roku device
Voice control not workingEnsure you're using a compatible Roku OS version
FAQs About Syncing Roku Remote to TV​
1. Can I sync multiple remotes to one Roku device?​
Yes, but only one voice remote can be paired at a time. You can use multiple IR remotes if desired.
2. Does syncing the remote erase my Roku settings?​
No, syncing or re-pairing the remote won’t affect your channels, preferences, or accounts.
3. Why doesn’t my Roku remote control the volume?​
Make sure you’ve completed the TV control setup in Roku settings and that your TV is compatible.
Final Thoughts​
Whether you’re using a basic IR remote or an enhanced voice remote, syncing your Roku remote to your TV only takes a few steps. From pairing button tricks to TV volume control setup, we’ve covered everything you need to know.
If you’re still stuck, drop a comment below—we’re happy to help you get your Roku remote synced and ready to stream.
