How to select Signal input on Xiaomi TV? The signal source is generally switched according to the type of signal input to the TV. The switching method is as follows.
1. If the TV is connected to the cable TV signal cable to watch cable TV programs, you should use the remote control. Please press the source button to switch the signal source of the TV to TV mode.
2. If the TV is connected to a digital TV set-top box or a DVD player, a remote control should be used. You can press the source button to switch the TV's signal source to video mode or HDMI mode. The exact source mode depends on which jack these devices are connected to on the TV.
3. If the TV is connected to the U disk to play the movie, you should switch the signal source of the TV to USB mode to watch it normally.
4. Generally, users can use the remote control of the TV without knowing what kind of equipment the TV is connected to. Just press the source key to pop up the source menu options, and then switch the source mode one by one, until the TV shows the screen that the user needs to stop switching.
