How to Restart Samsung TV: A Complete Guide
Restarting your Samsung TV can help fix software glitches, slow performance, and connectivity issues. Whether you're dealing with frozen apps, sound problems, or laggy navigation, a simple restart can often resolve the issue.
In this guide, we’ll cover multiple ways to restart a Samsung TV, including using the remote, power cycle, and factory reset options.
Why Restart Your Samsung TV?​
Over time, your Samsung Smart TV may experience issues due to memory overload or software errors. Restarting your TV can:
✅ Fix unresponsive apps
✅ Clear temporary system cache
✅ Improve TV performance and speed
✅ Resolve sound and display glitches
✅ Fix Wi-Fi and Bluetooth connectivity issues
Now, let’s explore the different ways to restart your Samsung TV.
How to Restart Samsung TV?​
Method 1: Restart Samsung TV Using the Remote (Soft Reset)​
The easiest way to restart your Samsung TV is by using the power button on your remote.
Steps to Restart Your Samsung TV via Remote:
  1. Turn on the TV – Ensure your Samsung TV is powered on.
  2. Press and hold the Power button – Point your remote at the TV and hold the Power button until the TV turns off.
  3. Wait for the TV to reboot – Keep holding the button until you see the Samsung logo appear, then release it.
This process performs a cold boot, which clears memory and refreshes the system without deleting any settings or installed apps.
Method 2: Restart Samsung TV by Unplugging (Power Cycle)​
If your TV is frozen, unresponsive, or experiencing lag, a power cycle (also called a hard reset) might be necessary.
How to Power Cycle Your Samsung TV:
  1. Turn off the TV – Press the Power button on the remote.
  2. Unplug the TV from the power source – Remove the plug from the wall socket.
  3. Wait at least 30 seconds – This helps drain residual power from the capacitors.
  4. Plug the TV back in – Reconnect the power cord to the outlet.
  5. Turn the TV back on – Press the Power button to restart your Samsung TV.
This method resets the TV’s power supply and can fix most temporary glitches.
Method 3: Restart Samsung TV Without Remote​
If you’ve lost your remote or it’s not working, you can restart your TV manually using the power button on the TV itself.
Steps to Restart Your Samsung TV Without a Remote:
  1. Locate the power button – It’s usually found on the bottom center, left, or right side of the TV.
  2. Press and hold the power button – Hold it for about 5–10 seconds until the TV turns off.
  3. Wait a few seconds and turn it back on by pressing the button again.
If your TV doesn’t respond, try unplugging it for 30 seconds and then plugging it back in.
Method 4: Factory Reset Samsung TV (Last Resort)​
If restarting doesn’t fix the issue, a factory reset can help. This will erase all settings, apps, and personal data, returning the TV to its original state.
How to Factory Reset Samsung TV:
  1. Press the Home button on your remote.
  2. Go to Settings > All Settings.
  3. Select General & Privacy > Reset.
  4. Enter your PIN (default PIN: 0000).
  5. Confirm the reset – The TV will restart and restore to factory settings.
⚠️ Warning: Only use this method if other restarts don’t work, as it erases everything.
Common Questions About Restarting a Samsung TV​
1. How often should I restart my Samsung TV?​
It’s good practice to restart your TV once a week to clear cache and optimize performance.
2. Why does my Samsung TV keep restarting?​
If your TV keeps rebooting, it might be due to overheating, outdated firmware, or a faulty power supply. Try updating the software or checking the power cable.
3. Does restarting delete apps or settings?​
No, a simple restart won’t delete any apps or settings. However, a factory reset will erase all data.
4. Can I restart my Samsung TV using a smartphone?​
Yes! If your remote isn’t working, you can use the Samsung SmartThings app on your phone to control and restart your TV.
Final Thoughts​
Restarting your Samsung TV is a simple yet effective way to resolve common performance issues. Whether you use the remote, unplug the TV, or perform a factory reset, these methods ensure smooth operation.
For best results, try a soft reset first, then a power cycle, and only reset to factory settings as a last resort.
If your Samsung TV keeps experiencing issues, consider checking for firmware updates or contacting Samsung Support.
Did this guide help? Let us know in the comments!
