How to Reset Samsung TV?
XLZ451
What's wrong with your TV? once you reset the TV, it will turn back to factory mode. There are some references if you really need them.
1. Navigate the Settings of your TV, and then select General.
2. Find and select Reset, then enter your PIN (0000 is the default), click the Reset option.
3. Click OK to complete the Reset. Now the TV will restart automatically.
