How to Reset Roku TV: A Step-by-Step Guide
Roku TVs are popular for their easy-to-use interface and access to a vast range of streaming content. However, like any smart device, they may sometimes experience issues such as lagging, freezing, connectivity problems, or unresponsive apps. Resetting your Roku TV can help resolve these problems and restore its performance.
In this guide, we’ll walk you through different methods to reset your Roku TV, including soft reset, factory reset via settings, and factory reset using the reset button.
When Should You Reset Your Roku TV?​
Before jumping into the reset process, it's important to know when a reset is necessary. You may need to reset your Roku TV if you experience:
  • Frozen screen or unresponsive remote
  • Connectivity issues with Wi-Fi or streaming services
  • Apps crashing or not loading properly
  • Audio or video issues
  • Persistent software glitches
  • Wanting to sell or give away the TV (Factory reset erases all personal data)
How to Reset Roku TV?​
Method 1: Soft Reset (Restart Roku TV)​
A soft reset (also called a restart) is a quick way to fix minor glitches without erasing your settings or data.
Steps to Soft Reset Your Roku TV:
  1. Using the Roku Remote:
    • Press the Home button on your Roku remote.
    • Navigate to Settings > System > Power > System Restart.
    • Select Restart and confirm.
  2. Using the Roku Remote (Shortcut Method):
    If your TV is frozen, try this button sequence to force a restart:
    • Press Home button 5 times.
    • Press Up Arrow once.
    • Press Rewind twice.
    • Press Fast Forward twice.
      Your Roku TV will restart automatically.
  3. Unplugging the TV:
    • Unplug the TV from power.
    • Wait for 30 seconds.
    • Plug it back in and turn it on.
This method does not delete apps or settings but can resolve many minor issues.
Method 2: Factory Reset via Settings (Erases All Data)​
If your Roku TV has persistent issues, or if you're selling or giving it away, a factory reset will restore it to its original state.
Steps to Factory Reset Roku TV via Settings:
  1. Press the Home Button on your Roku remote.
  2. Go to Settings > System > Advanced System Settings.
  3. Select Factory Reset.
  4. Choose Factory Reset Everything.
  5. Follow the on-screen instructions and enter the displayed code to confirm the reset.
  6. Your Roku TV will restart and return to its original setup screen.
🔹 Warning: This will delete all apps, accounts, and personal settings. You’ll need to set up the TV from scratch.
Method 3: Factory Reset Using the Reset Button (If Screen Is Unresponsive)​
If your Roku TV is completely frozen, you can use the physical reset button on the back or side of the TV.
Steps to Reset Using the Physical Button:
  1. Locate the reset button on the back of the Roku TV. It may be a small pinhole requiring a paperclip or a standard button.
  2. Press and hold the reset button for 10-30 seconds.
  3. The TV screen will turn off and then display the Roku logo, indicating the reset is complete.
  4. Set up your Roku TV again from the start.
Resetting Roku Remote​
If your Roku remote is not working, resetting it might help.
Steps to Reset Roku Remote:​
  1. Remove the Batteries from the Roku remote.
  2. Unplug your Roku TV and wait 10 seconds.
  3. Plug in the TV and wait until the home screen appears.
  4. Reinsert the Batteries into the remote.
  5. Pair the Remote: Press and hold the pairing button (inside the battery compartment) for 5 seconds until the pairing light blinks.
Troubleshooting Tips​
If resetting didn’t resolve your issue, try these additional troubleshooting steps:
✅ Check for Software Updates: Go to Settings > System > System Update and check for updates.
✅ Ensure a Strong Wi-Fi Connection: Poor internet can cause buffering or freezing. Restart your router if needed.
✅ Check HDMI Cables & Power Source: Loose connections can cause display issues. Ensure cables are properly plugged in.
✅ Contact Roku Support: If issues persist, visit Roku Support for further assistance.
Resetting your Roku TV is a simple but effective solution to fix common issues. Whether you need a soft reset to restart your TV, a factory reset via settings, or a hard reset using the reset button, this guide has covered everything you need to know.
If you're experiencing ongoing issues, try troubleshooting steps or check for software updates before opting for a factory reset. With these methods, your Roku TV should be back to working smoothly in no time!
