Serena Anderson
For us Apple TV fans, the happiness a remote can bring us also comes with the frustration it can cause when it is not working properly. In this article, I will take you through the process of resetting your Apple TV remote to ensure that your regular relaxation and entertainment flow are not interrupted.
First, let us explore the reasons that are demanding you to reset the Apple TV remote:
If a Siri Remote or an Apple TV Remote is the remote you have, just take the following as your next steps:
Try to do this method first if you have the older aluminum or white Apple Remote:
If after resetting your Apple TV remote you are still experiencing issues, we are suggesting the use of the following additional, supplementary steps:
Resetting your Apple TV remote is an easy technique that can solve many of the common problems that people experience. The tips in this tutorial on how to solve the problems will bring you back to your favorite films and programs in no time at all. If you still have problems, feel free to contact Apple Support for skilled assistance.
I hope you find this guide very resolving in terms of the issues of your Apple TV remote. So, happy streaming!
Why You Might Need to Reset Your Apple TV Remote
- Buttons are not reacting
- issue with the connection with the Apple TV
- Batteries get depleted
- Overcome software malfunctioning
How to Reset Apple TV Remote: Step-by-Step Guide
1. For Siri Remote (1st and 2nd generation) and Apple TV Remote
- For at least 6 seconds, unplug your power from your Apple TV
- Also, plug your Apple TV again
- Simultaneously, press and hold the TV button and Volume Down button for about 5 seconds
- Allow the keys to be released once the message is displayed on your TV screen.
- Your remote will be connected to your Apple TV by placing it on top of your Apple TV
2. For Apple Remote (aluminum or white)
- Then, your TV screen should be near your Apple TV
- Wait now for the Menu and Left buttons to be pressed and held for six seconds
- Let go of the buttons and see the thumbs-up message on the TV screen
Troubleshooting Tips
- Make sure to check whether the batteries need replacing or not
- Make sure that there are no barriers between your remote and the TV in the Apple CI unit
- Upgrade your Apple TV operating system to the newest version
- The last thing to do is contact Apple Support, and wait for them to give you expert help
