How to Pair Your Xfinity Remote to a TV? 3 Methods
1.1
Method 1: Pair Xfinity Remote to TV Automatically (XR11, XR15, XR16)
- 1.1.1 Steps to Automatically Pair Your Xfinity Remote:
- 1.1.2 Pros:
- 1.1.3 Cons:
1.2
Method 2: Pair Xfinity Remote to TV Using a Code (For Older TVs)
- 1.2.1 Steps to Manually Pair Your Xfinity Remote:
- 1.2.2 Pros:
- 1.2.3 Cons:
1.3
Method 3: Pair Xfinity Voice Remote to TV (XR15 & XR16)
- 1.3.1 Steps to Pair Using Voice Commands:
- 1.3.2 Pros:
- 1.3.3 Cons:
- 1.4 How to Reset an Xfinity Remote (If Pairing Fails)
1.1
- 2 Troubleshooting Tips
- 3 FAQs
- 4 Final Thoughts
Setting up your Xfinity remote to work with your TV allows you to control volume, power, and inputs without juggling multiple remotes. Whether you have an XR11, XR15, XR16, or another model, this guide will walk you through the exact steps to pair your Xfinity remote with your TV in just a few minutes.
Depending on your remote model, you can pair it to your TV using:
Let’s go step by step to ensure a smooth setup.
This method works best for modern TVs and newer Xfinity remotes with a setup button.
Fast and simple setup
Works for most modern TVs
No need to enter TV codes manually
May not work for older TVs
If automatic pairing doesn’t work, you can enter a TV manufacturer code manually.
Works for older TVs
Reliable backup method
Requires looking up the correct code
Can take multiple tries to find the right code
Xfinity voice remotes allow you to set up your TV using voice commands.
Quickest setup method
No need to press multiple buttons
Only works with Xfinity voice remotes
If your remote isn’t working correctly, reset it and try pairing again.
After resetting, follow the pairing steps again.
Remote not responding? Check batteries or try resetting.
TV not turning on/off? Try a different pairing code.
Volume buttons not working? Ensure HDMI-CEC is enabled on your TV.
No, Xfinity remotes can only be paired to one TV at a time. To use it with another TV, you must reset and re-pair it.
Try using a universal TV code (like 10000) or refer to Xfinity’s remote support page.
Yes! The remote can control basic TV functions like power and volume even without an Xfinity cable box.
If you paired your remote to the TV but not the Xfinity cable box, you need to reprogram it for full functionality.
Pairing your Xfinity remote to your TV is a simple process that takes just a few minutes. Whether you use automatic pairing, enter a TV code manually, or use voice commands, following this guide will get your remote working seamlessly.
Still having issues? Leave a comment below, and we’ll help you out!
- Automatic Pairing (Easiest method)
- Manual Code Entry (For older TVs or if automatic pairing fails)
- Pairing via Voice Commands (For voice remotes like XR15 and XR16)
- Turn on your TV and ensure your Xfinity remote has working batteries.
- Press and hold the "Setup" button (for XR11) until the LED light turns green.
- If your remote doesn’t have a Setup button (like XR15), press and hold the "Xfinity" and "Info" buttons together until the light turns green.
- Enter the 3-digit code that appears on your TV screen.
- Wait for confirmation—your remote is now paired!
- Turn on your TV.
- Press and hold the "Setup" button (or "Xfinity" + "Info" on newer remotes) until the LED light turns green.
- Enter your TV’s manufacturer code (Find the correct code on Xfinity’s official code lookup tool).
- Press the Power button—if the TV turns off, pairing is complete.
- If the TV doesn’t turn off, repeat with a different code from the list.
- Turn on your TV.
- Press and hold the "Microphone" button on your remote.
- Say “Program remote” and follow the on-screen instructions.
- Enter the 3-digit pairing code if prompted.
Steps to Reset Your Xfinity Remote:
- For XR15/XR16: Press and hold "A" + "D" buttons until the LED turns green, then enter 981.
- For XR11: Press and hold the Setup button until the light turns green, then enter 981.
FAQs
1. Can I pair my Xfinity remote to multiple TVs?
2. What if my TV brand isn’t listed?
3. Can I use my Xfinity remote without a cable box?
4. Why does my Xfinity remote change the TV volume but not the channels?
Final Thoughts
