How to Pair Roku Remote to TV: A Step-by-Step Guide
If you’ve recently purchased a Roku device or need to reconnect your remote, you may wonder how to pair it with your TV. Roku remotes come in two types: IR (Infrared) remotes and Enhanced (Wi-Fi) remotes. The pairing process varies depending on the type of remote you have.
This guide will walk you through how to pair a Roku remote to a TV, including troubleshooting steps if your remote isn't working properly.
How to Identify Your Roku Remote Type​
Before pairing, you need to determine whether you have an IR (Infrared) remote or an Enhanced (Wi-Fi) remote:
✅ IR (Infrared) Remote: Requires a direct line of sight to the Roku device. It does not have a pairing button.
✅ Enhanced (Wi-Fi) Remote: Uses a wireless connection and does not require direct line of sight. It has a pairing button inside the battery compartment.
Now, let’s go through the pairing process based on your remote type.
Method 1: Pair an IR Roku Remote (No Pairing Button)​
If your Roku remote is IR-based, it doesn’t require manual pairing. Simply follow these steps:
Steps to Pair an IR Roku Remote:​
  1. Insert new batteries into the remote.
  2. Point the remote at the Roku device (ensure there are no obstructions).
  3. Turn on your Roku device and wait for it to boot up.
  4. Press any button on the remote to check if it responds.
If the remote doesn’t work, try replacing the batteries or ensuring the Roku device is placed in an open area where the infrared signal isn’t blocked.
Method 2: Pair an Enhanced Roku Remote (With Pairing Button)​
If you have an Enhanced Roku Remote, you’ll need to manually pair it using the pairing button.
Steps to Pair an Enhanced Roku Remote:​
  1. Turn on your Roku TV or device and wait until the home screen appears.
  2. Insert fresh batteries into the remote.
  3. Locate the pairing button inside the battery compartment.
  4. Press and hold the pairing button for 5 seconds until the LED light starts flashing.
  5. Wait for the TV to display a message confirming the remote is paired.
Once paired, your remote should work immediately.
How to Pair a New Roku Remote Without the Old One​
If you've lost your old remote and need to pair a new one:
  1. Use the Roku Mobile App (Available for iOS & Android) to navigate the Roku menu.
  2. Go to Settings > Remotes & Devices > Pair New Remote.
  3. Follow the on-screen instructions to pair the new remote.
This method works best for Wi-Fi (Enhanced) remotes.
Troubleshooting Roku Remote Pairing Issues​
If your Roku remote isn’t pairing, try these solutions:
1. Restart Your Roku Device​
  • Unplug your Roku device or TV from power.
  • Wait 30 seconds, then plug it back in.
  • Try pairing the remote again.
2. Re-pair the Remote​
  • Remove the batteries from the remote.
  • Unplug the Roku device, wait 30 seconds, then plug it back in.
  • Insert the batteries back into the remote.
  • Press and hold the pairing button for 5 seconds.
3. Check for Interference (IR Remotes Only)​
  • Ensure no objects are blocking the signal between the remote and the Roku device.
  • Try moving the Roku device to a different location.
4. Try Different Batteries​
Weak or old batteries can prevent the remote from pairing properly.
5. Reset the Roku Remote​
If all else fails, you may need to reset the remote:
  • Hold the pairing button for 10 seconds while reinserting the batteries.
  • Try pairing it again.
Pairing your Roku remote to your TV is easy, whether you’re using an IR remote or an Enhanced Wi-Fi remote. If your remote isn’t working, try troubleshooting steps like restarting your Roku device, changing batteries, or resetting the remote.
With these simple steps, your Roku remote should be successfully paired and ready to use!
