How to hook up Apple TV with cable box? Usually there is an HDMI port on Apple TV, you just need to hook up Apple TV with cable box via an HDMI cable. There are the detailed steps.
Step 1
Plug the coaxial cable from the wall socket into the back of the cable TV box. Tighten the connector of the coaxial cable in a clockwise direction. The small pin will align with the small hole in the middle of the cable box jack.
Step 2
Align the HDMI cable plug with the correct connection on the back of the cable box. The HDMI cable can only be plugged in when the direction is correct.
Step 3
Connect the other end of the HDMI cable to the HDMI port of the TV. If you have multiple HDMI ports, please pay attention to the one you use.
Step 4
Plug the junction box into the power supply and wait for the system to connect. Turn on the set-top box and set your TV to the HDMI port you noted earlier.
Step 1
After the connection is complete, turn on the TV and set-top box.
Step 2
Switch the input signal source to the set-top box with the remote control.
Step 3
Switch the input source of the TV to the corresponding channel.
That's all for how to hook up AppleTV with cable box, if you have any questions, welcome to discuss below.
hdmi-cable" >How to hook up AppleTV with cable box via HDMI cable?
Step 1
Step 2
Step 3
Step 4
TV settings
Step 1
Step 2
Step 3
