How to Get HBO Max on LG G2 TV?
Radiohead
The 2022 LG G2 features an upgraded OLED Evo panel that allows for higher peak brightness. This guide will show you how to get HBO Max on your LG G2 TV.
1. Press the Home button on your remote to enter the home screen.
2. Select LG Content Store.
3. Select Apps.
4. Find HBO Max to install it.
5. If you can not find it, you can go to the Search icon and tap into HBO Max.
6. Choose Install.
