Harry Williams
Connecting wireless headphones to an older Samsung TV can be a game-changer, letting you enjoy private listening without disturbing others. While older models may lack built-in Bluetooth, there are workarounds to achieve a seamless wireless audio experience. Follow this step-by-step guide to get started.
What You Need:
How to Enable Bluetooth on a Streaming Device:
Steps to Connect:
How to Connect Wireless Headphones to an Old Samsung TV
Step 1: Check Your TV for Built-in Bluetooth
Before using additional devices, confirm whether your Samsung TV already has Bluetooth.- Navigate to the TV's Settings menu.
- Go to Sound > Sound Output > Check for a "Bluetooth Speaker List" option.
- Turn on your wireless headphones and enable pairing mode.
- Select your headphones from the Bluetooth Speaker List to complete pairing.
Step 2: Use a Bluetooth Transmitter for Non-Bluetooth TVs
A Bluetooth transmitter is the best solution for connecting wireless headphones to a TV without built-in Bluetooth.What You Need:
- A Bluetooth transmitter compatible with TVs
- A 3.5mm audio jack or RCA cable (depending on your TV's audio output)
- Plug the transmitter into the TV's audio output:
- Use the headphone jack or RCA ports on the back of the TV.
- Power up the transmitter:
- Some transmitters are battery-powered, while others connect via USB for power.
- Pair your wireless headphones:
- Enable pairing mode on both the transmitter and headphones.
- Wait for the connection to establish.
Step 3: Use a Streaming Device with Bluetooth Support
Another option is to use a streaming device like Roku, Amazon Fire Stick, or Apple TV, which includes Bluetooth audio support.How to Enable Bluetooth on a Streaming Device:
- Roku:
- Download the Roku app on your smartphone.
- Pair your headphones through the app and enjoy wireless audio.
- Amazon Fire Stick:
- Go to Settings > Controllers & Bluetooth Devices > Other Bluetooth Devices.
- Select and pair your wireless headphones.
- Apple TV:
- Navigate to Settings > Remotes and Devices > Bluetooth.
- Choose your headphones to connect.
Step 4: Use a Wireless RF Headphone System
If Bluetooth isn’t an option, consider using wireless RF headphones designed specifically for TVs. These headphones come with a base station that connects directly to your TV's audio output.Steps to Connect:
- Plug the RF transmitter base station into your TV's headphone jack or RCA ports.
- Turn on the base station and headphones.
- The headphones automatically connect via radio frequency for high-quality audio.
Troubleshooting Tips
- No Sound from Headphones:
- Ensure the TV's audio output is set to External Speakers or Headphones.
- Check that the transmitter and headphones are fully charged or powered.
- Audio Delay Issues:
- Choose a low-latency Bluetooth transmitter to minimize audio lag.
- Ensure your headphones support aptX Low Latency for the best experience.
- Connection Problems:
- Reset the Bluetooth transmitter and headphones by turning them off and back on.
- Ensure there are no other Bluetooth devices interfering with the connection.
