If you don't want to annoy others when watching TV, then you can connect your headphone with Samsung TV via Bluetooth. Here is the guide for you.
1. Using your Samsung remote control, press the Menu button and select Settings.
2. Choose Sound.
3.Then Sound Output.
4. Select Bluetooth Speaker List.
5. Now, switch your audio device to Bluetooth pairing mode.Make sure your headphone is turn on the paring mode.
6. Once your Bluetooth device appears, select the device then Pair and connect.
Now you can watch TV by yourself silently. For more information, refer to the Samsung TV Forum.
2. Choose Sound.
