Serena Anderson
Roku has been my long-time tech companion and I've encountered all sorts of remote-control issues with it. Sharing with you the in-depth information of the process of connecting your Roku remote to your TV, I present to you today. With the following guide you are sure to be back to your favorite TV shows in the shortest time possible.
Before we start the connection process, we'll need to know which Roku remote type you have first. Roku provides two main types:
If you have a regular IR-receiver, go through these simple steps:
Always note the fact that your IR remote is required to have a direct vision to the TV so remove any object that is in between the TV and the sensor of the remote.
If you have an enhanced remote in the sense that it is not the standard type, the process will be different from the above instruction:
The truth is you will receive a message from your Roku TV that will let you know that you have successfully paired the remote. If it doesn't work successfully at the first time, don't panic, usually repeating the process works for me.
In my usage of Roku gadgets during which I have encountered a few common things. Here are some quick fixes:
If the problem hasn't been resolved, I would then advise you to use the Roku mobile app. It can be a temporary remote while you troubleshoot the issues with your physical remote. I've found this to be a lifesaver in many situations!
You will be all right with your Roku remote if this article is to be taken as a basis. This article is built to provide guidelines on how to quickly bring life back to your TV remote with zero stress. Changing a language of the buttons or use another method will eventually help success, there.
If the issues persist after using the above-recommended methods, don't hesitate to get in touch with Roku's customer support. They are always available for assistance. I am also here to help you get through the process.
Understanding Your Roku Remote
- Standard IR Remote
- Enhanced "Point-Anywhere" Remote
Connecting a Standard IR Remote to Your Roku TV
- At the first place, turn on the Roku television.
- Direct the remote to the television set without any barriers between them.
- Press any of the button on the remote.
- Beside changing the batteries, if the remote still not works, try replacing the batteries.
Connecting an Enhanced "Point-Anywhere" Remote
- Take the battery cover off of your remote.
- Get the pairing button in the battery compartment for community location.
- Put your Roku television on.
- Hold your remote close to the television set.
- Press and hold the pairing button for 5 seconds.
- Wait for the flashing light on the remote that indicates that linking is doing.
Troubleshooting Common Issues
- Battery Issues: Be sure to start by replacing the batteries
- Pairing Problems: Check that your TV is on the home screen before the process of pairing the remotes.
- Interfeence: Put other electronic devices away from your Roku TV ect ya pas this one
Using the Roku Mobile App as a Temporary Solution
