Samuel Miller
- 1 Why You May Need to Reconnect or Pair Your Firestick Remote
- 2 What You’ll Need
- 3 How to Connect Firestick Remote to TV (Step-by-Step)
- 4 How to Pair a New Firestick Remote (If Replacing)
- 5 Troubleshooting Firestick Remote Pairing Issues
- 6 Does the Firestick Remote Control TV Power and Volume?
- 7 Final Thoughts
If your Firestick remote is not pairing or you’ve just purchased a new one, you might be wondering how to connect it to your TV quickly and easily. In this guide, you’ll learn how to connect Firestick remote to TV, troubleshoot pairing issues, and ensure seamless control over your Fire TV Stick.
There are several reasons why your remote might need to be reconnected:
Regardless of the reason, reconnecting your Firestick remote is usually a simple process.
Before you start, make sure you have:
Ensure your TV is on and set to the HDMI input where your Firestick is plugged in. Wait for the Fire TV home screen to load completely.
On your Firestick remote, press and hold the “Home” button for 10 seconds. This will initiate the pairing process.
If the remote doesn’t pair immediately, repeat this step a couple of times.
Once connected, try pressing:
If all buttons work, your Firestick remote is now successfully connected to your TV.
If you're adding or replacing a Fire TV remote:
This allows you to pair a new or secondary remote to your Fire TV Stick.
If your Firestick remote still won’t connect to your TV, try these fixes:
Yes—if you have the Alexa Voice Remote with TV controls, it can:
To enable TV controls:
Learning how to connect Firestick remote to TV only takes a few seconds once you know the correct steps. Whether you’re pairing a new remote, replacing batteries, or troubleshooting connection issues, following this guide ensures you’ll be back to streaming in no time.
If your remote still isn’t working after following all steps, consider resetting your Firestick or contacting Amazon support for further help.
- You've purchased a replacement remote
- Your remote lost connection due to a software update or power interruption
- You reset your Fire TV Stick
- You're pairing it to a new TV or device
What You’ll Need
- Your Amazon Fire TV Stick plugged into the TV
- A working remote with new batteries installed
- A powered-on TV set to the correct HDMI input
Step 1: Power on Your TV and Fire TV Stick
Step 2: Hold the Home Button for 10 Seconds
- A blinking LED light may appear on your remote
- Wait for an on-screen confirmation that the remote has been paired
Step 3: Test the Remote Functions
- Navigation buttons (up, down, left, right)
- Back or Home
- Power and Volume (if supported)
- Go to Settings > Controllers & Bluetooth Devices > Amazon Fire TV Remotes
- Select Add New Remote
- Hold the Home button on the new remote for 10 seconds
- Once detected, press Select on your old remote to confirm
- Replace the batteries with fresh ones (use Alkaline or rechargeable)
- Restart the Fire TV Stick by unplugging and replugging the device
- Reset the remote by holding Back + Menu + Left Arrow for 15 seconds
- Use the Fire TV app on your phone as a temporary remote via Wi-Fi
- Turn your TV on/off
- Control volume and mute
- Go to Settings > Equipment Control > Manage Equipment > TV
- Follow on-screen prompts to set up IR control for your specific TV brand
Final Thoughts
