The projector brand Emotn has released a new portable projector, Emotn N1, priced at $399 on Amazon. If you have bought this projector, you can connect it via the LAN with a wired network, or connect it to a wireless wifi, and here is the guide.
1. Make sure that there is an available Network wire.
2. Plug the Network wire into to Lan port on the Emotn N1 projector.
3. After pairing the remote with the Emotn N1, (How To Pair the Emotn N1 Projector remote), Press the Home button, navigate to Settings> Network
4. Select the wired network, and your Emotn N1 would be able to get contents.
1. Make sure that there is available Wifi.
2. Press the Home button, navigate to Settings> Network
3. Select the WIFI, and choose your available WIFI name.
4. If there are passwords, enter them and then finish connecting.
Now your Emotn N1 is connecting to the network, you can stream it on the applications.
How to connect Emotn N1 to the wired network?
How to connect Emotn N1 to Wifi?
