How to Connect Alexa Show 10 to Roku Smart TV: A Step-by-Step Guide
Are you looking to control your Roku Smart TV with your voice using the Alexa Show 10? The Alexa Show 10, with its built-in screen and smart capabilities, allows you to control compatible devices around your home, including your Roku Smart TV. Connecting these two devices can make your streaming experience even more seamless and hands-free.
In this guide, we’ll walk you through the steps to connect your Alexa Show 10 to your Roku Smart TV, so you can use voice commands to control playback, adjust volume, and more. Let’s dive in!
Why Connect Alexa Show 10 to Roku Smart TV?​
Connecting Alexa Show 10 to your Roku Smart TV brings several benefits:
  • Hands-free control: You can play, pause, or skip content on your Roku TV using just your voice.
  • Convenient voice commands: Alexa can help you search for specific shows, adjust volume, switch channels, and even turn your TV on or off.
  • Smart home integration: If you have other smart devices at home, linking Alexa with Roku TV helps create a cohesive smart home system.
Requirements Before You Begin​
To connect your Alexa Show 10 to a Roku Smart TV, you need to have:
  1. Alexa Show 10 connected to the internet via Wi-Fi.
  2. Roku Smart TV connected to the same Wi-Fi network as your Alexa device.
  3. Roku device with the Alexa app installed on your phone.
  4. Roku account and an active Roku subscription (for certain features).
Step-by-Step Guide: How to Connect Alexa Show 10 to Roku Smart TV​
Step 1: Set Up Your Roku Account​
If you haven’t set up your Roku TV yet, follow these initial steps:
  1. Power on your Roku TV and follow the on-screen instructions to connect to Wi-Fi.
  2. Sign in or create a Roku account on your TV by following the prompts.
  3. Make sure your Roku TV is connected to the same Wi-Fi network as your Alexa Show 10.
Step 2: Enable Roku Skill on Alexa App​
To link your Alexa Show 10 to your Roku TV, you’ll need to enable the Roku skill on the Alexa app. Here’s how to do it:
  1. Open the Alexa app on your smartphone.
  2. Tap the "More" button in the bottom-right corner.
  3. Select "Skills & Games" from the menu.
  4. In the search bar, type "Roku" and press search.
  5. Select the "Roku" skill from the search results.
  6. Tap "Enable to Use".
  7. Sign in with your Roku account credentials to link your Roku account to Alexa.
  8. Link your Roku device: Follow the on-screen instructions to link your Roku TV or Roku streaming device.
Tip: Make sure your Alexa Show 10 and Roku TV are both on the same Wi-Fi network to ensure they can communicate effectively.
Step 3: Discover Your Roku Device in Alexa​
After enabling the Roku skill, you’ll need to discover your Roku TV using Alexa.
  1. Go back to the Alexa app and tap on the Devices tab at the bottom.
  2. Select "Add Device".
  3. Choose "TV" and then select "Roku".
  4. Alexa will now search for your Roku TV on the same Wi-Fi network.
  5. Once your Roku device is found, tap "Continue" to complete the setup.
Note: If Alexa can’t find your Roku TV, ensure both devices are connected to the same Wi-Fi network and try again.
Once Alexa has discovered your Roku TV, you’ll need to assign a name to your Roku device for easier voice control.
  1. Rename your Roku TV (if necessary) in the Alexa app to something easy for voice commands, such as “Living Room TV.”
  2. After that, your Alexa Show 10 will be able to control the Roku Smart TV using voice commands.
Step 5: Control Roku TV with Alexa Show 10​
After successfully connecting your Alexa Show 10 to your Roku Smart TV, you can now start using voice commands. Here are some examples of what you can say:
Basic Voice Commands:
  • "Alexa, turn on the Roku TV."
  • "Alexa, turn off the Roku TV."
  • "Alexa, play [movie/show] on Roku."
  • "Alexa, pause the Roku TV."
  • "Alexa, skip to the next episode."
Advanced Commands:
  • "Alexa, open Netflix on Roku."
  • "Alexa, search for [title] on Roku."
  • "Alexa, set the Roku TV volume to 50."
  • "Alexa, play [song/playlist] on Roku TV."
These voice commands allow you to control your Roku Smart TV hands-free, making your entertainment experience more convenient.
Troubleshooting Tips​
1. Roku Device Not Detected​
If Alexa is not detecting your Roku TV, make sure both devices are on the same Wi-Fi network. You may also need to check that your Roku TV is powered on and connected to the internet.
2. Alexa Unable to Control Roku TV​
If voice commands aren’t working as expected, try these steps:
  • Ensure that your Roku device is linked correctly in the Alexa app.
  • Restart both your Roku TV and Alexa Show 10.
  • Make sure that your Roku TV is set to "TV" mode.
3. Roku Skill Disabled​
If the Roku skill has been disabled or isn’t responding, go to the Alexa app and re-enable the Roku skill by following the same steps as in Step 2.
Conclusion: Easily Control Your Roku TV with Alexa Show 10​
Connecting your Alexa Show 10 to your Roku Smart TV is a great way to enhance your entertainment experience. Once linked, you can easily control your Roku TV with just your voice—whether it's turning it on, searching for content, or adjusting the volume.
By following the steps outlined above, you’ll be able to enjoy hands-free control and access to your favorite shows and movies with ease. If you run into any issues, simply follow the troubleshooting tips to get everything back on track.
