How to connect AirPods to Vizio TV via Bluetooth
Gamesaa
This article will introduce how to connect AirPods to VIZIO TV via Bluetooth. Apple AirPods work via Bluetooth AAC/SBC, but Vizio TVs work via Bluetooth LE, which will not work if you plan to pair Apple AirPods via Bluetooth.
Bluetooth transmitter
In this case, you need a Bluetooth transmitter to help you. All you have to do is search the web for Bluetooth transmitters, there are plenty of cheap and easy-to-use ones on sale, and with them, you can easily use them with your Apple AirPods.
After purchasing a Bluetooth transmitter, you can connect it to your Vizio TV via the aux port, speaker, RCA or coaxial port, depending on the transmitter model.
Then press the power button to put the AirPods in pairing mode. You've successfully connected your AirPods to your Vizio TV.
SimonK
Another way to connect AirPods to Vizio TV is to run Apple TV on Vizio TV and connect AirPods to your Apple TV.
First, on the back of the AirPods case, press and hold the button until the blinking white light turns on.
Then, on Apple TV, open Settings > Remotes & Devices > Bluetooth. Your AirPods should appear to complete the pairing process.
