If you own a laptop that supports Bluetooth connectivity, you can connect it to a Bluetooth speaker for better sound quality. The following are the specific steps to connect Bluetooth Speaker to a laptop.
1. Enter pairing mode
Adjust the Bluetooth speaker to Bluetooth pairing mode;
2. Turn on the computer's Bluetooth
Then turn on Bluetooth in the laptop settings;
3. Connect the Bluetooth speaker
Scan for nearby Bluetooth devices in the computer's Bluetooth settings, and select the corresponding Bluetooth speaker to connect.
Bluetooth speakers can be connected to audio sources through Bluetooth. As long as the laptop supports the connection of Bluetooth devices, it can be connected to the speaker through the Bluetooth of the laptop. Of course, there are also some Bluetooth speakers that support both Bluetooth and wired connections.
How to connect a Bluetooth speaker to a laptop?
