mtn328
Whether the projector lens is clean has always been a concern for users. A lot of times, once you find dust on the lens, you wipe it. However, the tools and techniques used by many users are not correct, resulting in scratches and damage to the lens. Here we share the tools and steps needed to wipe the projector lens.
Projctor Cleanning Kit
Steps of Cleaning Projector Lens
The above is all the tools and steps needed to clean the projector lens.
- Lens Tissues: choose one with soft texture, no dandruff
- Air Blower: choose one with good elasticity and large volume, so that strong wind can be enough. Besides, if you blow the ball for a long time, you should change it as soon as possible, otherwise the lens will only get dirtier and dirtier.
- Lens Cleaning Spray: choose one that can be used to deal with grease stains and is highly volatile and will not cause secondary pollution to the lens.
- Cotton swabs: choose cotton swabs with long and neat fibers, and prepare both large and small ones.
- Firstly, blow out the dust and sand particles with large particles on the outer surface of the lens by blowing a balloon;
- Then use the lens paper to carefully wipe away the thick dirt that has not been blown away. Be careful when wiping, and gently wipe;
- Dip a cotton swab with a little lens cleaning fluid to get rid of the dirt and stains with tight attachment by means of sticking or picking;
- After making sure that there are no visible dust particles on the lens surface, wipe it again with a cotton swab coated with a little lens cleaning fluid. Wipe it from the center of the lens to the outer ring in a spiral shape.
- Wipe the mirror in the same way with a clean cotton swab until there is no lens cleaner. If a wipe is not complete, try again with a new cotton swab, and finally with the lens swab paper from the center of the circle to gently wipe until the lens is completely clean and tidy.
