This guide will show you how to add/delete widgets in JMGO O1 Pro Companion Mode.
1. Make sure your smartphone is paired with your JMGO O1 Pro projector.
2. Turn to the "Companion" tab in the JMGO App.
3. To delete widgets:
Click "Manage" at the top right corner. You'll see a list of current widgets and can either change their order or delete any one of them.
4. To add widgets:
Click "More" of the "Digital Art Gallery" section and you'll find all available artworks. Enter the one you desire and hit the "Add Widget" button to add it.
4. To add widgets:
