In the projector system Settings, find the image mode, and you can adjust the color parameters in the image mode, or adjust the image parameters set for the projector system to restore the primary color;
If the projector's green light caused by the internal light machine, it needs to be dismantled and repaired. It is relatively complicated, and it is recommended to be operated by professionals.
