Barend Ray
Active member
If you need to sign out of Netflix on your TV, the process can vary depending on the device or TV model. This guide outlines all the possible ways to log out, helping you easily manage your account access.
If the menu options are hidden or unavailable, try using the remote shortcut method. Alternatively, you can reinstall the Netflix app to clear account data.
2. What Happens After Logging Out?
Once you log out, the device will return to the login screen. Your account details won’t be accessible until re-entered.
3. How Do I Log Out Remotely?
If you don’t have physical access to the TV:
Not usually, but if none of the methods work, uninstalling and reinstalling Netflix is a surefire way to log out.
			Why You Might Need to Log Out of Netflix
- You’re switching accounts or sharing the TV with others.
- You're troubleshooting account-related issues.
- You’re selling or giving away the device.
Step-by-Step Guide to Logging Out of Netflix on TV
Method 1: Using the Netflix App
- Open the Netflix App: Launch Netflix from your TV's app menu.
- Access the Menu: Use your remote to move left until the menu appears.
- Navigate to "Get Help" or "Settings": Scroll down to find either option.
- Select "Sign Out": Choose this option and confirm when prompted.
Note: Some older Netflix versions might label the settings option differently.
Method 2: Using the Netflix Remote Shortcut
If the standard method doesn’t work:- On your remote, press these buttons in order:- Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up.
- A hidden menu will appear. From here, select:- Sign Out
- Start Over
- Deactivate
Method 3: Device-Specific Logout Instructions
1. Roku TVs- Open Netflix, go to the menu, and follow the steps to "Get Help" or use the shortcut method mentioned above.
- Open Netflix, press the "Info" or "Options" button on your remote, and select "Deactivate."
- From the Netflix app, navigate to the "Settings" option. Under "Account," choose "Sign Out."
- Navigate to "Settings" > "Applications" > "Manage Installed Applications." Select Netflix and "Clear Data," which effectively logs you out.
- Open Netflix, head to "Settings" within the app, and select "Sign Out."
FAQ: Common Issues and Troubleshooting
1. I Can’t Find the "Get Help" or "Sign Out" OptionIf the menu options are hidden or unavailable, try using the remote shortcut method. Alternatively, you can reinstall the Netflix app to clear account data.
- Go to the Netflix Account Settings.
- Select "Sign Out of All Devices."
Helpful Tips
- For Shared TVs: Always log out when done to maintain privacy.
- For Troubleshooting: Logging out and back in can resolve common playback issues.
- For Selling Devices: Ensure you perform a full factory reset after logging out.
