In the period of being trapped by the epidemic, I believe many people find it not easy to find leisure and entertainment programs suitable for the whole family at home. Compared with the users who have only one TV in the living room, the players who have built high-end private cinemas or even simple living room cinemas can see, hear and play much more content. Many movie and video lovers began to consider adding projectors to their living rooms to get a large screen experience close to the cinema. So, what are the conditions for a projector to be placed in the living room? We can learn a little about the new 4K home projector launched by Epson some time ago, the CH-TW 7000.
CH-TW 7000: 4K pro-uhd technology to improve the overall picture performance
With 3lcd display chip and "4K pro-uhd" technology, it is divided into two camps with DLP models at the same price. It is reported that the combination of 4K PRO-UHD technology and Epson 3LCD core display technology enables users to achieve both pixel and brightness when watching, achieving more excellent picture analysis, higher color brightness and 16 segment adjustable HDR, which not only enables the projection picture to present more details of each frame, but also enables the dark color to be more profound, colorful and restore the true color of the picture, no matter what During the day and night, the projector can present clear, bright and vivid high-quality pictures.
CH-TW 7000: Up to 3000 lumens of white and color brightness
The white brightness and color brightness of the CH-TW7000 have reached 3000 lumens. At the same time, the 16 segment adjustable "HDR10 setting" function can increase the brightness of the input signal to 10000 nit at most. When properly matched with the brightness, contrast and other screen adjustment options, the high light and black position of the CH-TW7000 can present a superior state.
In terms of color performance, CH-TW7000 can reach the rec.709 standard of nearly 94% in the Cinema mode. Thanks to the excellent color brightness, CH-TW7000 finally presents a balanced and natural color, which continues the Epson projector's always fresh and elegant style. The picture's delicacy and color hierarchy are also impressive.
CH-TW 7000: Large range lens displacement, multi angle projection, wireless connection to Bluetooth devices.
The volume of CH-TW7000 is relatively small 410 × 164 × 330mm, about 6.6kg. Because the exhaust port and the suction port are respectively located in the front and side of the projector, the CH-TW7000 can give full play to the potential of 1.6 times zoom lens without too much space reserved for the rear wall during the hanging and installation. A distance of about 3 meters can project a large picture of 100 inches.
Large range lens displacement (horizontal displacement is up to 24%, vertical displacement is up to 60%), and multi angle projection can be realized from the side, and the placement position is random. Correspondingly, the space requirements are also very small, which is not only suitable for the living room environment, but also no problem for the bedroom and study with a smaller area.
Ch-TW7000 supports Bluetooth function, and can connect all kinds of audio devices equipped with Bluetooth function wirelessly, such as Bluetooth speaker, sound bar, etc. users can easily set up different specifications of wireless theater system according to their preferences and budget.
CH-TW 7000 SPECS
Display chip: 0.61 inch 3lcd chip
10 bit image processing technology
Display resolution: 3840 × 2160
White brightness: 3000 lumens
Color brightness: 3000 lumens
Contrast: 40000:1
Reference life: 3500 hours (power consumption: high) / 4000 hours (power consumption: medium) / 5000 hours (power consumption: ECO)
Lens displacement range: vertical ± 60%, horizontal ± 24%
Projection size: 40-500 inches (1.16-14.87m)
Volume (w × h × d): 410 × 164 × 330mm
Weight: about 6.6kg
Reference price: RMB 17800
CH-TW 7000 SPECS
Contrast: 40000:1
Weight: about 6.6kg
