cleanyourclam
- 1 Specs
- 2 Which to get
In the world of portable projectors, the HONPOW Portable Mini Projector and the Generic Mini Portable Projector represent two distinct philosophies. On one hand, you have the HONPOW, boasting an impressive 4K resolution and a brightness of 11,000 lumens, making it a powerhouse for vivid imagery even in bright environments. It also features advanced connectivity options, allowing for seamless screen mirroring without the need for WiFi, which is particularly appealing for outdoor use.
On the other hand, the Generic Mini Portable Projector offers a much lighter, more pocket-friendly design. While its resolution and light output may seem underwhelming at just 854x480 and 50 lumens, it does come with a two-year warranty and is tailored for those who prioritize portability over raw power.
So, which projector is truly better for your needs? Is it worth investing in the high-end features of the HONPOW, or does the compact convenience of the Generic model win out? Let’s dive deeper into the specs and see how they stack up against each other.
On the flip side, we have the Generic Mini Portable Projector. This one is ultra-portable, weighing in at just 206 grams, making it super easy to take anywhere. But the downside is the resolution is only 854x480 and the brightness is much lower at 50 lumens, which might not cut it for movie nights unless you're in a dark room. It does have a 2-year warranty, which is nice, but I'm not sure if the visual quality would leave much to be desired compared to the HONPOW.
So, factoring in picture quality, sound, system features, and potential downsides, which one do you think is the better buy? Would love to hear your thoughts!
Specs
Parameter | HONPOW Portable Mini Projector | Generic Mini Portable Projector |
Reference Price | $139.99 | - |
Recommended Uses | Home Cinema | Education, Home Cinema, Gaming, Business |
Built-In Media | Power Cord, User Manual, HDMI Cable | User Manual, 64GB SD TF Card, Remote, HDMI Cable, Carrying Bag |
Highlight | ![]() ![]() ![]() | 2 year warranty. Ultra-Portable Design: This compact and lightweight projector, weighing only 206g, is perfect for users who want to take their presentations or movies on-the-go. Its pocketable design makes it easy to carry in a bag or pocket. High-Quality Visual Experience: With a resolution of WVGA 854x480 and a contrast ratio of 500:1, this projector provides a clear and vibrant visual experience. The LED lamp offers a light output of 50 lumens, suitable for presentations and small screenings. Advanced Connectivity Options: Equipped with 2.4G/5G dual WiFi and Bluetooth 4.0, this projector allows users to connect to the internet and stream content seamlessly. It also supports Android 9.0, enabling users to access a wide range of apps and features. |
Screen Size | 60 Inches - 200 Inches | 30 Inches - 170 Inches |
Throw Distance | 4.9 Feet - 16.4 Feet | 1 Meters - 5 Meters |
Contrast Ratio | 10000:1 | 2000:1 Pixels |
Maximum Resolution | 3840x2160 Pixels | 4096 x 2160 Pixels Per Inch |
Native Resolution | 1920 x 1080 | 4096 x 2160 |
Brightness | 11000 Lumen | 100 Lumen |
Display Type | LCD | DLP |
Other Features | Keystone Correction, Focus, Timed Off, 5.1 Bluetooth, 5G WIFI | Portable, Digital Keystone Correction, Lightweight, Multiple screen sizes, 3d-Ready |
Video Encoding | H.264, MPEG-4, AVC, MJPEG | - |
Lamp Wattage | 10 Watts | - |
LightSource Life | 50000 Hours | - |
Controller Type | Hand Control | Remote Control, Button Control |
Control Method | Remote | Remote, Touch |
Connectivity Technology | Wireless | Wireless, Bluetooth, USB, HDMI |
Compatible Devices | ['Television', 'Gaming Console', 'Laptop', 'Smartphone'] | Projector, Television, Tablet, Smartphone, Speaker |
Wattage | 65 watts | - |
Mount Type | Tabletop Mount | Tripod Mount |
L x W x H | 9.7"L x 8.1"W x 3.7"H | 5"L x 3"W x 3"H |
Which to get
So I'm in the market for a mini projector and I've come across two options that seem pretty different. First up is the HONPOW Portable Mini Projector. It's got 4K picture quality, which sounds incredible for watching movies or even just casual viewing. With 11,000 lumens brightness and a high contrast ratio, it promises vibrant and detailed images even in brighter settings. Plus, the built-in 10W speaker and Bluetooth 5.1 connectivity for sound seem like a big win for a mini projector. However, I wonder if the sound is really as good as it claims and if there are any issues with portability since it’s a bit bulkier.On the flip side, we have the Generic Mini Portable Projector. This one is ultra-portable, weighing in at just 206 grams, making it super easy to take anywhere. But the downside is the resolution is only 854x480 and the brightness is much lower at 50 lumens, which might not cut it for movie nights unless you're in a dark room. It does have a 2-year warranty, which is nice, but I'm not sure if the visual quality would leave much to be desired compared to the HONPOW.
