Hisense U8N Mini-LED TV Review: Is It Worth the Hype?
WWGHIAFTC
First Impressions​
The Hisense U8N has a premium design overall. It has thin bezels on the sides and the top, with a slightly thicker bottom bezel. Unlike 2023'sHisense U8/U8K, the TV uses a central stand instead of two feet.
The back is made of plastic and has a grid-like pattern that resembles a lot of Sony TVs. Most of the inputs are side-facing, but theyre close enough to the edge of the TV that they are accessible when its wall-mounted. A USB, ethernet, and optical port are located in a recessed cutout that faces the back. Unfortunately, these arent accessible if you have the TV mounted flush to the wall. The TV has a built-insubwoofernear the top, and you can funnel cables through the TVs stand to help withcable management.
The TV has great build quality. Its mostly made of plastic, but its sturdy and well-built overall. The new center-mounted stand provides good stability, and there are no glaring issues with the TVs design. Our unit did have somepixel level smudges, but these arent noticeable from a normal viewing distance.
Hinsense u8n U8N​
$999.29​
Model Year​
2024​
Specific Uses​
Entertainment, Gaming​
Stand, TV, Power Cable, Remote​
Highlight
Display Size: 65 inches
Display Technology: Mini-LED Pro+ with Full Array Local Dimming Pro
Peak Brightness: Up to 3000 nits
Local Dimming Zones: 2000+
Processing Chipset: Hi-View Engine Pro
AI Features: Dynamic Tone Mapping Pro, Face Detection, AI HDR Enhancement, AI Detail Enhancement
Streaming Platform: Google TV
Audio Technology: Dolby Atmos, 2.1.2 multi-channel sound system
Gaming Features: 144Hz Game Mode Pro, AMD FreeSync Premium Pro, Auto Low Latency Mode, Low Latency MEMC
System​
Hinsense u8n U8N​
Operating System​
Google TV​
Internet Applications​
Netflix, Disney Plus, Prime Video, Hulu, YouTube​
Bluetooth​
The Hisense U8N delivers a smooth and user-friendly experience with its Google TV operating system. It boasts an impressive selection of apps, providing easy access to favorite content. Additionally, the ability to cast from a mobile device or play videos from a USB stick adds to its versatility. However, the presence of non-removable ads in the smart interface may detract from the overall experience for some users.
Hinsense u8n U8N​
Aspect Ratio​
16:9​
Display Technology​
QLED, Mini Led, LED, LCD​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
144 Hz​
Response Time​
8 Milliseconds​
Viewing Angle​
178 Degrees​
HDR Format​
HLG, HDR10, HDR10+, Dolby Vision​
Maximum Brightness​
2500 Nit​
Backlight Technology​
Mini-LED​
Backlight Setting​
Full Array Local Dimming​
Backlight Configuration​
Direct-Lit​
Full Array Local Dimming, Wide Color Gamut, Quantum Dot Color​
Motion Enhancement​
Motion Rate 480​
Viewing Experience
The Hisense U8N delivers an impressive overall performance, particularly in terms of contrast and HDR color accuracy. Its ability to produce deep blacks, especially with local dimming enabled, allows for a visually striking experience that rivals higher-end models. The HDR color gamut is excellent, with strong coverage of DCI-P3 and decent Rec. 2020, although some colors, particularly in the green and blue spectrum, fall short.
While the TV excels in handling reflections and maintains brightness effectively in bright environments, it does have limitations in viewing angles, leading to gamma and color shifts when viewed off-center. Blooming performance is generally good, though noticeable in specific scenarios. The gray uniformity presents some challenges, but black uniformity is superb when local dimming is active. Overall, the Hisense U8N stands out for its contrast, color accuracy, and brightness, making it a strong contender for various viewing environments, despite some drawbacks in viewing angles and specific color performance.
Audio​
Hinsense u8n U8N​
Audio Channels​
2.1.2​
Surround Sound​
Dolby Atmos​
Audio Encoding​
Dolby Atmos​
Audio Output​
Surround​
Audio Input​
HDMI​
Speaker Description​
Dolby Atmos​
Speaker Output Power​
50 Watts​
Audio Experience
The Hisense U8N offers a decent audio experience with a built-in subwoofer that adds some bass, though it may not be sufficient for those seeking a more impactful sound. While the TV excels in clarity for dialogue at moderate volume levels, the sound quality becomes unbalanced and distorted as the volume increases. Overall, the TV performs adequately at lower volumes, but users should be mindful of the distortion that occurs at higher settings.
Hinsense u8n U8N​
Laptop, Gaming Console, Headphone​
Water Resistance​
Not Water Resistant​
Tuner Type​
ATSC​
D x W x H​
2.9"D x 57"W x 33.1"H​
Mount Standard​
600 x 400 mm​
Voltage​
120 Volts​
Power Consumption​
280 Watts​
Line Voltage​
100-240 VAC 50-60 Hz​
Full Array Local Dimming Pro, Dolby Vision IQ · Atmos, Mini-LED ULED, Native 144Hz, QLED Quantum Dot Color​
Motion Smoothing
The Hisense U8N TV delivers commendable performance, particularly in handling low-quality content by effectively smoothing out artifacts while maintaining detail. Its response time is impressive, ensuring minimal blur during fast-moving scenes, although it does exhibit some black smearing during dark scene transitions. The TV's behavior with variable refresh rates can be inconsistent, particularly around the 100Hz mark, which may be distracting for some users. Additionally, the use of pulse width modulation for backlight dimming results in flicker that is mostly unnoticeable due to its high frequency. While the motion interpolation feature aims to enhance motion clarity, it falls short, producing noticeable artifacts, especially in fast-moving scenes. Overall, the Hisense U8N offers a solid viewing experience with some caveats in specific areas.
Connectivity​
Hinsense u8n U8N​
Bluetooth Version​
5.3​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
2​
USB2.0 Ports​
1​
USB3.0 Ports​
1​
Audio Out Ports​
2​
HDMI Ports​
4​
Connector Type​
Signal Format​
ATSC​
Sharing Direction​
Mobile to TV​
Hardware Interface​
Bluetooth, USB, Ethernet, HDMI​
Connecting TV
Overall Impression: This TV excels in delivering an exceptional gaming experience with its remarkably low input lag in PC/Game Mode, making it highly responsive for gamers. Its compatibility with the latest PS5 features, including 1440p @ 120Hz and 4K @ 120Hz, combined with support for HDMI Forum VRR and Auto Low Latency Mode, ensures seamless gameplay. The inclusion of HDMI 2.1 ports enhances its capability for high-resolution content, while eARC support enables high-quality audio transmission. Additionally, the TV's support for all HDR formats and an ATSC 3.0 tuner allows for versatile viewing options, including over-the-air 4K content. Overall, this TV is well-equipped for both gaming and high-definition media consumption.
User Feedback​
Pros
• Excellent picture quality with vibrant colors and deep blacks
• Large 75" size is immersive, perfect for a home theater experience
• Good sound quality with a decent subwoofer
• Great for streaming 4K content, providing a cinematic feel
• Affordable pricing, especially with discounts and extended warranty options
• Bonus offer of NBA2k25 with purchase adds value
Cons
• Google TV interface is sluggish and less responsive compared to competitors
• Reflections can be problematic in bright rooms
• Atmos feature does not significantly enhance sound experience due to lack of upward firing speakers
Overall Impression
The Hisense U8N is a compelling choice for those seeking an impressive 75" 4K TV experience, boasting remarkable picture quality and sound. Despite some drawbacks with the Google TV interface and reflection issues, it offers great value, especially during sales and with the bonus of an extended warranty. If you're looking for an immersive home theater experience, this TV is worth considering, but be prepared for potential interface quirks.
