Hisense QD7N Review: A Solid Choice with HDMI 2.1 for Gamers and Movie Lovers?
cruets620
First Impressions​
The Hisense 65QD7N features a similar design to many other budget Hisense models, with a metal back enclosure, plastic housing for the inputs, and a set of plastic feet. Its simple, but its a functional design that looks good enough.
The top section of the TV is metallic, and the section that houses the inputs is made of plastic. Most of the inputs are side-facing, but theyre located towards the middle of the TV, making them hard to reach when the TV is wall-mounted. The Ethernet, digital audio out, and the USB port that are located on the back are inaccessible if you have it mounted flush to the wall. Unfortunately, the TV doesnt come with any clips to help withcable management.
The TVs build quality is alright. It wobbles a bit on its feet when pushed on, and theres some minor flexing on the back, but this is to be expected and doesn't cause issues. Unfortunately, our unit has abulgethat slightly separates the glass from the LCD.
Hisense QD7N​
$598​
Model Year​
2024​
Specific Uses​
Entertainment, Gaming​
Stand, TV, Remote Control, Power Cable​
Highlight
Display Size: 74.5 inches
Display Type: QLED
Resolution: 3840 x 2160 (4K)
Refresh Rate: 144Hz
Gaming Features: AMD FreeSync Premium Pro, Auto Low Latency Mode, Low Latency MEMC
Audio Technology: Dolby Atmos
Voice Control: Yes, included remote
System​
Hisense QD7N​
Operating System​
Google TV​
Internet Applications​
Disney Plus, Netflix, Prime Video, Hulu, YouTube​
Bluetooth​
The Hisense QD7 Series offers a smooth and user-friendly experience with its version 12 Google TV operating system. While the presence of non-disableable ads in the smart interface is a downside, the TV compensates with a robust selection of apps, ensuring easy access to a variety of content. Additionally, features like casting from a phone and USB playback enhance its versatility for content consumption. Overall, the Hisense QD7 Series presents a solid option for users seeking an intuitive and functional smart TV experience.
Hisense QD7N​
Aspect Ratio​
16:9​
Display Technology​
QLED​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
144 Hz​
Response Time​
8 Milliseconds​
Viewing Angle​
178 Degrees​
HDR Format​
HLG, HDR10, HDR10+, Dolby Vision​
Maximum Brightness​
390 Nit​
Backlight Configuration​
Direct-Lit​
Motion Enhancement​
Motion Rate 240​
Viewing Experience
The Hisense QD7 presents a mixed overall impression. It struggles significantly with contrast, as blacks appear gray and dark scenes look washed out due to the absence of a local dimming feature. While the TV offers a very good HDR color gamut with strong DCI-P3 coverage, the colors lack saturation and accuracy, resulting in a less vibrant viewing experience.
Gray uniformity is only decent, with noticeable variations across the screen, although it excels in dark scenes. The viewing angle is satisfactory, providing some consistency but suffering from brightness loss and color washout at wider angles, making it less ideal for group viewing.
Reflection handling is good for indirect reflections, but direct reflections can be distracting. Overall, the Hisense QD7 delivers a subpar performance in contrast and color accuracy, while showing some strengths in reflection handling and decent gray uniformity in specific conditions.
Audio​
Hisense QD7N​
Audio Channels​
2.0​
Surround Sound​
Dolby Atmos​
Audio Encoding​
Dolby Atmos​
Speaker Output Power​
30 Watts​
Audio Experience
The Hisense QD7 delivers a sound experience that is generally well-balanced, particularly at moderate volume levels, making it suitable for clear dialogue. However, it struggles with bass production and experiences an imbalance at higher volumes, limiting its overall loudness. While distortion is minimal during regular use, it becomes noticeable at maximum volume, indicating that the sound quality is best appreciated at lower levels. Overall, the audio performance of the Hisense QD7 is adequate but falls short for those seeking a more robust and dynamic sound experience.
Hisense QD7N​
Laptop, Gaming Console, Tablet, Headphone, Speaker​
Water Resistance​
Not Water Resistant​
Tuner Type​
ATSC​
D x W x H​
3.4"D x 66"W x 37.8"H​
Mount Standard​
400 x 300 mm​
Voltage​
120 Volts​
Power Consumption​
230 Watts​
Line Voltage​
100-240 VAC 50-60 Hz​
Sleep Timer, Game Mode, Multiple Voice Assistance, Wide Color Enhancer, Flat​
Motion Smoothing
Overall Impression: The Hisense QD7 delivers impressive performance, particularly in handling low-quality content by effectively smoothing out artifacts while preserving detail. Its fast response time minimizes blur during fast motion, enhancing viewing experiences. However, the use of pulse width modulation for dimming may cause flicker at lower brightness settings, which could be a concern for sensitive viewers. The optional motion interpolation feature enhances clarity in slower scenes, but it struggles with fast-moving content, leading to noticeable artifacts. Overall, the TV offers strong capabilities, with some caveats regarding flicker sensitivity and motion handling in certain scenarios.
Connectivity​
Hisense QD7N​
Bluetooth Version​
5.3​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
2​
USB2.0 Ports​
1​
USB3.0 Ports​
1​
Audio Out Ports​
2​
HDMI Ports​
4​
Connector Type​
Signal Format​
ATSC​
Sharing Direction​
Mobile to TV​
Hardware Interface​
Bluetooth, USB, Ethernet, HDMI​
Connecting TV
The TV delivers an impressive gaming experience with its incredibly low input lag, especially in PC/Game Mode, allowing for seamless interaction during gameplay. It supports high resolutions and refresh rates, including 1080p @ 240Hz with a commendable input lag of 2.8 ms, though users may encounter a random bug that requires a power cycle to resolve. Fully compatible with PS5 features such as 1440p @ 120Hz and 4k @ 120Hz, it boasts HDMI 2.1 capabilities on select ports, ensuring ample bandwidth for high-quality visual performance. The inclusion of eARC enhances audio connectivity, allowing for high-quality audio transmission to compatible devices. Overall, the TV stands out for its gaming-friendly features and robust support for modern audio and visual formats.
User Feedback​
Pros
• Easy setup
• Great picture quality
• Excellent value for the price
• Superior sound and picture quality compared to more expensive brands
• Fast user interface and snappy menus
• Good performance for gaming with features like 144 VRR
Cons
• Lack of a full instruction manual
• Poor packaging leading to potential damage during shipping
• Sound quality may require an additional soundbar for better experience
Overall Impression
The Hisense TVs offer remarkable picture quality and value for money, making them a strong contender in the market. While the setup is straightforward and the interface is user-friendly, concerns about packaging and sound quality may warrant consideration. Overall, for those seeking a budget-friendly smart TV with impressive features, Hisense delivers significantly on its promise.
