Hisense PX3-PRO Review: Is This Budget RGB Laser UST Projector Worth Your Money?
First Impressions​
The Hisense PX3-PRO isnt meant to be portable as its quite heavy and lacks an integrated battery, so you need to plug it in. The projector has a feature for auto keystone correction, but it requires you to go through a few extra steps, such as scanning a QR code and uploading a picture of the projected image. Furthermore, it doesnt work well, so ultimately, youll most likely need to adjust the image geometry manually, and it also doesnt have autofocus.It doesnt have an adjustable stand, but it does have adjustable feet. It has a 50W Harman Kardon speaker system, so you won't need to worry about connecting it to a soundbar if you move it.
The Hisense PX3-PRO uses a laser light source, which requires no maintenance and will last for 25,000 hours or more, according to the manufacturer. Its not a true 4k projector, as it uses pixel shifting to create a higher-resolution image. This offers better quality than a pure 1080p projector but isnt as good as a native 4k projector.It's an Ultra Short Throw (UST) projector, so it can project a 90-inch image at a distance of 6.6 inches and up to a 130-inch image at a distance of 14.3 inches, which is significantly closer to the wall than its predecessor, theHisense PX1-PRO.
Hisense PX3-PRO​
$3497.97​
Entertainment, Education, Home Cinema, Gaming, Business​
Projector, User Manual, Power Cord, Remote, Cleaning Kit​
Highlight
UST Projector for XBOX
HSR 240 High Refresh Rate
Auto-Low Latency Mode
IMAX Enhanced
Dolby Atmos & Harmon Kardon Speakers
Active 3D Ready
Dolby Vision
3000:1 Native Contrast
Hisense PX3-PRO​
80 Inches - 150 Inches​
0.46 Meters - 0.12 Meters​
3000:1​
3840 x 2160 Pixels​
3840 x 2160​
3000 Lumen​
Laser​
Dolby Vision & IMAX Enhanced​
Viewing Experience
The Hisense PX3-PRO projector delivers impressive peak brightness, making it suitable for viewing in moderately lit environments while offering vibrant and punchy colors. Its uniformity is acceptable, with a slightly brighter center compared to the edges; however, this is unlikely to be a significant issue for most viewers. The projector excels in contrast, particularly in darker scenes, providing rich blacks for an enhanced viewing experience in dim settings. While its contrast performance may lessen in brighter scenes, it remains strong overall. Additionally, the projector boasts an extensive color gamut, effectively covering the Rec. 709 color space with only minor deviations, and performs nearly as well in the wider Rec. 2020 spectrum, although it shows slight undersaturation in some greens. Overall, the Hisense PX3-PRO is a solid choice for those seeking vibrant colors and good performance in various lighting conditions.
Hisense PX3-PRO​
AVC​
25000 Hours​
Remote Control, App Control, Button Control, Voice Control​
App​
250 watts​
Hardware Connectivity​
Ethernet, HDMI, USB 3.0, Bluetooth 5​
Advanced LPU Technology, Ultra Short Throw, 4K AI Upscaler, High Contrast Ratio, HDR and Wide Color Gamut, Dolby Vision Atmos, IMAX Enhanced, Google TV, Active 3D, Harmon Kardon Speakers​
21.7"L x 11.7"W x 4.8"H​
The Hisense PX3-PRO is a versatile and feature-rich projector that stands out for its built-in Google TV, allowing seamless streaming and content casting through Chromecast and Airplay 2. Its integrated 50W Harman Kardon sound system enhances the audio experience, making it suitable for various entertainment needs. The projector is well-equipped with multiple HDMI ports, including two HDMI 2.1 and one HDMI 2.0 port, ensuring compatibility with a range of devices. Additionally, the inclusion of USB ports and support for Bluetooth 5.3 and Wi-Fi 6e provide excellent connectivity options. Overall, the Hisense PX3-PRO combines advanced technology with user-friendly features, making it a compelling choice for those seeking a high-quality projection experience.
User Feedback​
Pros
• Excellent image quality in low light conditions
• Impressive performance on a standard white screen
• Easy setup and adjustment
• Film-Maker mode enhances viewing experience
• Convenient remote control with picture and audio shortcuts
• Good sound quality for a projector; can be improved with external sound system
• Compatible with various streaming apps via Google TV
• Sufficient Wi-Fi capabilities for streaming
Cons
• Performance decreases in well-lit environments
• Lacks advanced Wi-Fi 6, 6e, or 7 support
• Requires external soundbar for optimal audio experience
• Occasional issue with the projector turning on by itself
• No TV tuner included, which may limit local channel access
Overall Impression
The PX1 projector is a strong contender for anyone looking to enhance their media room experience, particularly in dark settings. Its high-quality image output and ease of use make it a worthwhile investment, especially for those who prioritize streaming content. However, potential buyers should be aware of its limitations in brighter environments and consider additional audio solutions for a more immersive experience.
