Hisense PX1-PRO Review: Is This Laser Projector the Right Choice for You?
windstri85
First Impressions​
The projector isnt meant to be portable as its quite heavy and lacks an integrated battery, so you need to plug it in. The projector has a feature for auto keystone correction, but it doesnt work well, so youll need to adjust the image geometry manually, and it also doesnt have autofocus. It has a 30W speaker system, so you wont need to worry about connecting it to a soundbar if you move it.
This projector uses a laser light source, which requires no maintenance and will last for 25,000 hours or more, according to Hisense. Its not a true 4k projector, as it uses pixel shifting to create a higher-resolution image. This offers better quality than a pure 1080p projector but isnt as good as a native 4k projector. Its an Ultra Short Throw (UST) projector, so its capable of projecting a 90 image at a distance of 10.7 and up to a 130 image at a distance of 19.3.
Hisense PX1-PRO​
$1895​
Gaming​
Remote, Power Cable​
Highlight
Protection: Full HISENSE USA Protection + 1 Year Extended Plan
Laser Colors: Red + Green + Blue
Color Gamut: 107% BT.2020
Projection Size: 90 to 130 inches
Resolution: 4K
Refresh Rate: 60Hz
HDR: HDR10 High Dynamic Range
Brightness: 2200 Lumens
Audio: 30W Dolby Atmos Sound
Platform: Android TV
Hisense PX1-PRO​
90 Inches - 130 Inches​
1M:1​
3840 x 2160 Pixels​
3840 x 2160​
2200 Lumen​
DLP​
TriChroma Laser Engine, 107% BT.2020 Color​
Viewing Experience
The Hisense PX1-PRO offers a decent performance with its peak brightness and white light output, making it suitable for use in darker environments. However, the color output is less impressive, lacking vibrancy, and the contrast levels are only okay, resulting in less defined blacks. While it features a wide color gamut, it tends to oversaturate colors in the Rec. 709 color space, although it excels with HDR content in the Rec. 2020 space. Overall, the projector is functional for specific viewing conditions but may not satisfy users seeking rich colors and deep contrasts.
Hisense PX1-PRO​
HEVC​
25000 Hours​
App, Remote, Voice​
200 watts​
Bluetooth, USB, Ethernet, HDMI
Hardware Connectivity​
USB​
Laptop, Gaming Console, Smartphone, Tablet​
Dolby Atmos, Dolby Digital; Game Mode with ALLM; Filmmaker Mode; Buttery Smooth Motion; Voice Assistant and Alexa Voice Control​
20.5"L x 12.8"W x 6.3"H​
Overall Impression: The projector offers a seamless and user-friendly experience with its built-in Android TV and full Chromecast integration, allowing for easy content streaming directly from mobile devices. The integrated 30W Dolby Atmos sound system enhances audio quality, making it suitable for immersive viewing. With multiple connectivity options, including two HDMI 2.1 ports (one with eARC support) and USB ports, along with Bluetooth capability, this projector is versatile and well-equipped for various entertainment needs.
User Feedback​
• Exceptional picture quality with vibrant colors
• Great performance in well-lit environments
• Compatible with large screens (e.g., Vava 100" ALR Screen)
• Smooth gaming experience at 120Hz on Xbox Series S and PS5
• Crisp and clear visuals for a premium viewing experience
• Limited information on long-term durability
• May require specific screen types for optimal performance
• Price point may be higher than entry-level projectors
The Hisense PX1-Pro is an impressive projector that excels in picture quality and performance, particularly for gaming and bright environments. Its vibrant colors and clarity make it a standout choice for home entertainment enthusiasts. While it may come at a higher price, the value it offers in terms of visual experience is noteworthy.
