Hisense CanvasTV Review: Is This QLED the Right Fit for Your Home Entertainment?
Harry Williams
First Impressions​
The Hisense S7 is designed to look more like a framed piece of art than a traditional TV. It has a teak colored frame by default, but you can buy other colors from Hisense.
The back of the TV is plain and made entirely of plastic. Most of the inputs are side-facing and arent too hard to access when the TV is mounted flush against the wall. The TV has clips on its back to help withcable management, although the cables then dangle directly from the back as there isnt any way to hide them.
The TV has excellent build quality. Its made entirely of plastic, and its frame is made of aluminum, but made to look like wood. The frame blocks part of the first row of pixels, but its not something youll notice from a normal viewing distance. When using the stand, theres some wobble from front to back when the TV is pushed, but this doesnt cause any issues. Its well-built overall, and there are no issues with quality control.
Hisense CanvasTV​
$999.99​
Model Year​
2024​
Specific Uses​
Entertainment, Gaming, Display​
TV, Remote Control, Power Cable, UltraSlim Wall Mount, Teak Frame​
Highlight
Display Size: 65 inches
Display Type: QLED
Resolution: 3840 x 2160 (4K)
Refresh Rate: 144Hz
Audio System: Multi-channel 2.0.2 surround sound
Smart TV Platform: Google TV
Connectivity: Built-in Wi-Fi, Bluetooth, multiple HDMI ports
Viewing Modes: Art Mode, Game Mode Pro, Variable Refresh Rate
System​
Hisense CanvasTV​
Operating System​
Google TV​
Internet Applications​
Disney Plus, Netflix, Prime Video, Hulu, YouTube​
Bluetooth​
Overall Impression: The Hisense Canvas TV delivers a smooth and user-friendly experience with its Google TV operating system, boasting a wide selection of apps for easy access to favorite content. However, the presence of non-removable ads in the smart interface may detract from the viewing experience for some users. The added functionality of casting from mobile devices and playing videos directly from a USB stick enhances its versatility.
Hisense CanvasTV​
Aspect Ratio​
16:9​
Display Technology​
QLED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
144 Hz​
Response Time​
8 Milliseconds​
Viewing Angle​
178 Degrees​
HDR Format​
HLG, HDR10, HDR10+, Dolby Vision​
Backlight Technology​
LED​
Backlight Setting​
Multiple​
Backlight Configuration​
Direct-Lit​
Quantum Dot and Dolby Vision HDR​
Motion Enhancement​
Motion Rate 480​
Viewing Experience
The Hisense Canvas TV presents a mixed overall impression. While it boasts an impressive HDR color gamut with good coverage of the DCI-P3 color space, it falls short in contrast performance due to the absence of local dimming. This limitation results in washed-out blacks and compromised dark scene visibility, detracting from the viewing experience. The TV does offer decent gray uniformity and good black uniformity, but its off-angle viewing is inadequate, making it less suitable for wide seating arrangements.
Additionally, while the reflection handling is generally good, the matte coating can diffuse glare to a degree that impacts perceived contrast. The BGR subpixel layout may affect text clarity for PC use, though it does not pose problems for video or gaming content. Overall, the Hisense Canvas TV excels in color performance but struggles significantly with contrast and viewing angles, making it a less favorable option for those prioritizing these aspects.
Audio​
Hisense CanvasTV​
Audio Channels​
2.0.2​
Surround Sound​
DTS Virtual:X​
Audio Encoding​
DTS​
Audio Output​
Surround​
Audio Input​
HDMI​
Speaker Description​
2.0.2 channel surround sound system​
Speaker Output Power​
36 Watts​
Audio Experience
The Hisense Canvas TV delivers an acceptable viewing experience with a decent frequency response, but it falls short in sound quality, particularly in the bass department. While it can reach high volume levels, this often comes at the cost of distortion, especially at max volume. Listeners may find it necessary to keep the volume at moderate levels to avoid noticeable sound distortion, making it less ideal for those prioritizing audio fidelity. Overall, it serves well for casual viewing, especially if volume is more critical than sound clarity.
Hisense CanvasTV​
Laptop, Gaming Console, Tablet, Headphone, Smartphone​
Water Resistance​
Not Water Resistant​
Tuner Type​
ATSC​
D x W x H​
1.4"D x 57.1"W x 32.8"H​
Mount Standard​
400 x 300 mm​
Voltage​
120 Volts​
Power Consumption​
200 Watts​
Line Voltage​
100-240 VAC 50-60 Hz​
Native 144Hz Game Mode PRO, Low Reflection Hi-Matte Display, Multi-Channel Surround Sound, UltraSlim Wall Mount & Magnetic Frame Included, Art Mode, Google TV​
Motion Smoothing
The Hisense Canvas TV delivers impressive performance, especially in handling low-quality content by effectively smoothing out artifacts while maintaining detail. Its quick response time minimizes blur during fast-moving visuals, providing a consistent viewing experience. The use of pulse width modulation for backlight dimming, while potentially bothersome for sensitive viewers, operates at a high frequency that makes flicker largely imperceptible. Additionally, the optional motion interpolation feature enhances motion clarity, showing better performance than many budget TVs, particularly in slower scenes, although it may struggle with faster action. Overall, the TV presents a strong package for those prioritizing smooth motion and low-quality content handling.
Connectivity​
Hisense CanvasTV​
Bluetooth Version​
5.3​
Wireless Technology​
Bluetooth, Wi-Fi​
Audio Out Ports​
1​
HDMI Ports​
4​
Connector Type​
Signal Format​
ATSC​
Hardware Interface​
Bluetooth, USB, Ethernet, HDMI​
Connecting TV
The Hisense Canvas TV delivers an exceptional gaming experience with its remarkably low input lag of just 4 ms in PC/Game Mode, allowing for fast and responsive gameplay. It fully supports next-gen gaming features, including 1440p @ 120Hz and 4k @ 120Hz, along with HDMI Forum VRR and Auto Low Latency Mode, ensuring a seamless transition between different gaming settings without manual adjustments. The inclusion of HDMI 2.1 bandwidth on multiple ports enhances its capability, allowing for high-resolution gaming without sacrificing performance. Additionally, the eARC support ensures high-quality audio transmission to compatible sound systems, making it a versatile choice for both video and audio performance. Overall, the Hisense Canvas TV stands out for its gaming-focused features and comprehensive support for modern audio and video standards.
User Feedback​
• Excellent picture quality
• User-friendly interface
• Good sound quality
• Attractive aesthetic with wood grain frame included
• Free preprogrammed art and easy customization options
• Ability to upload personal photos and art
• Music playback via Bluetooth in art mode
• Affordable price compared to competitors
• Limited selection of artwork available
• Audio issues reported shortly after purchase
• Requires a special box to hide cables for a clean look
• Slightly less flush against the wall compared to competitors
The Hisense Canvas TV impresses with its combination of quality, aesthetics, and features, particularly its art mode, which is enhanced by free preprogrammed art and customization options. While it offers great value for money, with a beautiful wood frame included, some limitations in artwork selection and reported audio issues should be noted. Overall, it stands as a strong alternative to more expensive options like the Samsung Frame TV, particularly for those seeking a stylish and functional addition to their living space without breaking the bank.
