Amanda Brown
Active member
- 1 First Impressions
- 2 Introduce
- 3 System
- 4 Display
- 5 Audio
- 6 Features
- 7 Connectivity
- 8 User Feedback
First Impressions
The Hisense75U8Nlooks the same as the other sizes. It has a premium design overall, with thin bezels on the sides and top and a slightly thicker bottom bezel.The back is made of plastic and has a grid-like pattern that resembles a lot of Sony TVs. Most of the inputs are side-facing, but theyre close enough to the edge of the TV that they are accessible when its wall-mounted. A USB, Ethernet, and optical port are located in a recessed cutout that faces the back. Unfortunately, these arent accessible if you have the TV mounted flush to the wall. The TV has a built-insubwoofernear the top, and you can funnel cables through the TVs stand to help withcable management.
The Hisense U8N 75-inch has great build quality. Its mostly made of plastic, but its sturdy and well-built overall. The center-mounted stand provides good stability, and there are no glaring issues with the TVs design. Unfortunately, our unit did have somedirt behind the screen. Its not noticeable with most content, but it's a bit distracting in scenes that have large areas of uniform color.
Parameter | Hisense 75U8N |
Reference Price | $1298 |
Model Year | 2024 |
Specific Uses | Entertainment, Gaming |
Built-In Media | Stand, TV, Power Cable, Remote |
Highlight | • Display: 75-inch Mini-LED QLED, 4K UHD, HDR, 2500 nits peak brightness • Performance: Hi-View Engine Pro chipset, Dolby Vision/Atmos • Gaming: 144Hz refresh rate, AMD FreeSync Premium Pro, Game Mode Pro • Smart TV Platform: Google TV, user-friendly interface, personalized recommendations |
System
Operating System | Google TV |
Internet Applications | Netflix, Disney Plus, Prime Video, Hulu, YouTube |
Remote Control | Bluetooth |
Controller Type | Remote Control, Voice Control |
System Experience | The Hisense 75U8N delivers a user-friendly experience with its smooth Google TV interface, making navigation effortless. It boasts an impressive array of apps, ensuring easy access to a wide range of content. However, the presence of non-removable ads within the smart interface may detract from the overall enjoyment for some users. Additionally, features such as content casting from mobile devices and direct video playback from USB sticks enhance its versatility. Overall, the Hisense 75U8N is a capable smart TV that excels in app selection and usability. |
Aspect Ratio | 16:9 |
Display Technology | QLED, Mini Led, LED, LCD |
Screen Finish | Flat |
Has Color Screen | Yes |
Resolution | 4K |
Refresh Rate | 144 Hz |
Response Time | 8 Milliseconds |
Viewing Angle | 178 Degrees |
HDR Format | HLG, HDR10, HDR10+, Dolby Vision |
Maximum Brightness | 2500 Nit |
Backlight Technology | Mini-LED |
Backlight Setting | Full Array Local Dimming |
Picture Enhancement | Full Array Local Dimming, Wide Color Gamut, Quantum Dot Color |
Motion Enhancement | Motion Rate 480 |
Viewing Experience | The Hisense 75U8N delivers a solid performance overall, showcasing impressive HDR color gamut capabilities with great coverage of the DCI-P3 and Rec. 2020 color spaces, although some colors, particularly vibrant greens and blues, may appear undersaturated. Its contrast performance is enhanced through local dimming, resulting in deep blacks in darker environments, though the contrast ratio is not as strong as smaller models, leading to some visible blooming around bright objects. The TV excels in reflection handling, effectively minimizing distractions from both direct and indirect light sources. While the gray uniformity is decent, some issues like a dirty screen effect and vignetting are present. The viewing angle is adequate but suffers from noticeable degradation at extreme angles, which may limit its suitability for wider seating arrangements. Overall, the Hisense 75U8N offers a compelling viewing experience with notable strengths in color accuracy and reflection management, despite some limitations in contrast and uniformity. |
Audio
Audio Channels | 2.1.2Ch |
Audio Encoding | Dolby Atmos |
Audio Input | HDMI |
Speaker Description | Dolby Atmos |
Speaker Output Power | 50 Watts |
Audio Experience | The Hisense U8N 75-inch TV delivers an overall satisfactory audio experience, characterized by clear dialogue and adequate loudness for typical viewing scenarios. Its built-in subwoofer adds a touch of bass, enhancing the sound quality, though it doesn't quite match the bass response of the smaller 65-inch model. While the TV performs well at moderate volume levels with minimal distortion, it does struggle with balance at maximum volume and exhibits some distortion, making it advisable to limit volume levels for optimal sound quality. |
Compatible Devices | Laptop, Gaming Console, Headphone |
Tuner Type | ATSC |
D x W x H | 2.9"D x 65.8"W x 38"H |
Mount Standard | 600 x 400 mm |
Voltage | 120 Volts |
Power Consumption | 350 Watts |
Other Features | Full Array Local Dimming Pro, Dolby Vision IQ · Atmos, Mini-LED ULED, Native 144Hz, QLED Quantum Dot Color |
Motion Smoothing | The Hisense 75U8N presents a solid performance in smoothing low-quality content, effectively minimizing artifacts while maintaining detail. Its response time is commendable, particularly for fast-moving images, although it exhibits some inconsistencies with Variable Refresh Rate (VRR) enabled, especially above 100Hz, leading to overshoot errors. While this behavior can be distracting, it is less pronounced compared to other models with VA panels. The use of pulse width modulation (PWM) for backlight dimming operates at a high frequency of 7800Hz, which should be less intrusive for sensitive viewers. However, the motion interpolation feature falls short, struggling with both slow and fast-moving scenes, resulting in noticeable artifacts and haloing. Overall, the TV offers a good viewing experience with specific strengths and weaknesses in motion handling and content processing. |
Connectivity
Bluetooth Version | 5.3 |
Usb Ports | 2 |
USB2.0 Ports | 1 |
USB3.0 Ports | 1 |
Audio Out Ports | 2 |
HDMI Ports | 4 |
Connector Type | USB, Ethernet, HDMI |
Signal Format | ATSC |
Hardware Interface | Bluetooth, USB, Ethernet, HDMI |
Connecting TV | The Hisense 75 U8N TV delivers an exceptional gaming experience with its incredibly low input lag of just 3.1 ms in PC/Game Mode, making it highly responsive for gamers. It is fully compatible with PS5 features, supporting resolutions up to 4K at 120Hz and 1440p at 120Hz, along with HDMI Forum VRR and Auto Low Latency Mode for seamless gameplay. The TV's HDMI 2.1 ports offer high bandwidth, accommodating up to 4K at 144Hz on select ports, while maintaining eARC functionality for high-quality audio transmission. Furthermore, it supports all HDR formats and includes an ATSC 3.0 tuner for enhanced viewing of over-the-air 4K content. Overall, the Hisense 75 U8N stands out for its advanced gaming capabilities and comprehensive audio-visual support. |
User Feedback
Pros• Outstanding image quality on the 75-inch model
• Deep and accurate color vibrance on the 75-inch
• Extremely deep black contrast on both models
• Excellent out-of-the-box settings on the 75-inch
• No significant difference in black depth between the two models
• Clean white colors on the 75-inch, free of pinkish hues
• Magnificent built-in speakers and subwoofer on both models
Cons
• Pale colors and inferior brightness on the 85-inch model
• Pinkish hue in white images on the 85-inch model
• Difficulty in adjusting color settings on the 85-inch
Overall Impression
The 75-inch U8N TV model stands out with its exceptional image quality, vibrant colors, and deep black contrast, making it a superior choice over the 85-inch model despite its larger size. The 85-inch struggles with color accuracy and brightness, which detracted from its performance. Overall, the 75-inch model is highly recommended for those prioritizing image fidelity and color accuracy.
