GooDee Mini Projector vs TMY Ultra Mini Projector vs AKASO WT50: Which Bluetooth Mini Projector is Right for You?
Barend Ray
Active member
GooDee Mini Projector​
TMY Ultra Mini Projector​
AKASO WT50 Mini Projector​
$299.99​
$149.99​
$269.99​
Home Cinema, Gaming​
User Manual, Power Cord, Battery, Remote, Cleaning Kit​
Adaptor, User Manual, Remote, HDMI Cable, Cleaning Kit​
360° rotatable support bracket, possibly others​
Resolution: 4K
Technology: DLP
Brightness: 500 ANSI lumens
Projection Distance: 1.64 to 9.85 feet (optimal 10 to 100 inches)
Max Screen Size: Up to 150 inches
Dimensions: 5.9 x 3.9 x 0.9 inches
Weight: Approximately 2.6 pounds
Keystone Correction: Automatic vertical ±45°
WiFi Capabilities: 2.4G and 5G
Bluetooth: Built-in
Battery: 7000mAh rechargeable
Battery Life: Up to 2.5 hours
Charging Options: Power bank compatible
Connectivity: Compatible with smartphones, iPads, laptops, TV boxes, DVD players, game consoles, USB drives
Dustproof Design: Yes
Dimensions: 3.82*3.42*1.33 in
Weight: 0.53 lb
Battery Capacity: 5000mAh
Playback Time: 3.5 hours
Projection Technology: DLP
WiFi Connectivity: 5G
Audio Connectivity: Bluetooth
Ports: HDMI, MicroSD, USB
Size: 5.7 x 3.15 x 0.79 inches
Weight: 0.64 lbs
Battery: 5000mAh, approx. 2 hours projection
Projection Technology: DLP (0.2DMD)
Image Quality: Clear, sharp visuals, high brightness, rich colors
Connectivity: Wireless (AirPlay, WiFi display, EShare, DLNA), USB, HDMI, Audio, Micro SD
Operating System: Android 9.0
App Support: Over 3 million apps from Google Play Store
Control Options: Remote control, touchscreen panel, automatic keystone correction
Note: Check accessories on arrival, use original charging cable only
Unboxing Experience​
GooDee Mini Projector:​
The GooDee Mini Projector has a compact and travel-friendly design, which makes it an excellent choice for those on the go. Its size is manageable, fitting easily into a carrying case that comes with it, along with a mini tripod and remote. The build quality feels solid and not flimsy, which instills a sense of trust in its durability. Overall, the design is functional and aesthetically pleasing, making it a good addition to any travel kit.
TMY Ultra Mini Projector:​
I was genuinely taken aback by the TMY Ultra Mini Projector's sleek and compact design. Its palm-sized form factor makes it incredibly portable, fitting easily into any travel bag or even a pocket. The projector's modern aesthetic is visually appealing, and its lightweight nature allows for effortless transport. I appreciate the attention to detail in its construction, making it not just functional but also stylish for any setting, whether at home or on the go.
AKASO WT50 Mini Projector:​
The projector boasts a compact and lightweight design, roughly the size of a smartphone but thicker, making it highly portable for various uses. The construction feels solid, and it comes with a mini tripod, adding to its versatility. The packaging is also commendable, ensuring the projector arrived in perfect condition. Overall, it gives off a very professional and well-thought-out vibe that reflects careful design.
3E+1 Inches - 150 Inches​
3E+1 Inches - 120 Inches​
1.49 Feet - 10 Feet​
5 - 0.5 Meters​
N/A - 13.78 Feet​
> 1000:1​
[Probably at least] 1000:1​
1280 x 720 Pixels​
360 x 640 Pixels​
1280 x 720​
640 x 360​
500 Lumen​
50 lumen​
DLP​
DLP​
DLP​
Digital Light Processing (DLP)​
DLP​
DLP​
The viewing experience is generally positive, with bright and clear images, particularly in darker environments. The projector performs admirably for movie nights or casual viewing, providing decent color reproduction and clarity. However, some users have pointed out that the brightness may not be sufficient in well-lit rooms, and the onboard speaker leaves something to be desired, prompting many to opt for external speakers. Still, the projector's ability to connect with streaming devices like Roku enhances its versatility for various viewing needs.
The viewing experience with this little projector has been impressive overall. The image quality, while not comparable to high-end televisions, delivers vibrant colors and sharp details, especially in dimmer lighting conditions. I found it particularly enjoyable for movie nights, where I could cast content directly from my devices. The projector performs well in ambient light, though it excels in darker environments, allowing for a vivid and immersive viewing experience. Despite its compact size, I was able to project a large image that filled my bedroom wall.
The image quality provided by the projector is notably sharp and bright, even in less-than-ideal lighting conditions. Users have reported excellent clarity, whether projecting small images for cookie decorating or larger visuals for movie viewing. However, the performance can suffer in bright environments, where a darkened room is ideal for optimal results. Additionally, while the projector supports various apps, video playback can be choppy without the use of external devices, which has been a point of frustration for some.
Built-In Speaker, Dust-Proof, Portable, Built-In Wi-Fi, Short Throw​
Built-In Speaker, Portable, Lightweight, Ultra Short Throw, Wi-Fi Ready​
Portable, Digital Keystone Correction, Lightweight, Built In Wi Fi, Short Throw​
AVC​
MP4​
MP4, AVC​
30000 Hours​
App Control​
Button Control​
Touchpad Control​
App​
Touch​
Bluetooth, Wi-Fi, USB, HDMI
Wi-Fi, USB, HDMI, 3.5mm Jack​
Television, Laptop, Smartphone, Tablet, Gaming Console​
Smartphone, Gaming Console, Laptop, USB device, HDMI device​
15 watts​
Mount Type​
Floor Mount,Ceiling Mount,Floor Mount,Tabletop Mount,Tripod Mount,Wall Mount​
Tabletop Mount/Ceiling Mount/Floor Mount/Tripod Mount​
Tabletop Mount​
10"L x 8"W x 3"H​
3.78"L x 3.38"W x 1.14"H​
5.71"L x 3.15"W x 0.79"H​
Setting up the GooDee Mini Projector is a straightforward process, with a clean interface and intuitive controls. It supports various connectivity options, including USB, USB-C, and HDMI, allowing users to connect devices easily. While the projector comes with a remote control, which enhances the ease of use, some users have noted that the initial loading time for USB devices can be slow, leading to some frustration during setup. However, once everything is connected, the projector is ready to deliver an enjoyable viewing experience.
Setting up the TMY Ultra Mini Projector was a breeze. The user interface is intuitive, allowing me to navigate through options quickly without any hassle. It accommodates a variety of connectivity options, including HDMI, USB, and Bluetooth, which means I could easily hook it up to devices like my Apple TV or Fire TV Stick. There were no complicated instructions to follow, and I was projecting within minutes, making it perfect for someone who isn’t particularly tech-savvy.
Setting up the projector was a breeze, with most users appreciating the ease of connecting to Wi-Fi and the device's ability to sync with phones and external devices like FireSticks and Chromecasts. The initial unboxing experience was enjoyable, and the setup process was straightforward and user-friendly, allowing users to get started with their projects or movie nights quickly. However, there have been some complaints regarding the remote control's functionality, which requires close proximity for effective operation.
- Compact and portable design, perfect for travel.
- Easy setup with multiple connectivity options.
- Good image quality in darker settings.
- Comes with useful accessories like a remote and carrying case.
- Decent performance with streaming devices.
- Brightness may not be sufficient for well-lit environments.
- Onboard speaker quality is lacking, often requiring external sound solutions.
- Initial loading times for USB devices can be slow.
- Limited customer service experiences reported by some users.
The GooDee Mini Projector is a commendable choice for those seeking a budget-friendly, portable projector for casual use, be it for outdoor movie nights or travel entertainment. While it has its limitations, particularly in brightness and audio quality, the overall performance is impressive for its price point. Many users have found it to be reliable and effective for their needs, making it a worthwhile investment for movie enthusiasts on a budget.
• Compact and portable design
• Easy setup with intuitive interface
• Good picture quality with vibrant colors
• Versatile connectivity options (HDMI, USB, Bluetooth)
• Suitable for various environments (indoor and outdoor)
• Long battery life for short viewing sessions
• Requires a constant refocus as the unit warms up
• Built-in speaker lacks volume and clarity
• Some connectivity issues with iPhone AirPlay
• Remote control requires line-of-sight and cannot power the unit on
• Not as bright in well-lit environments
My experience with the TMY Ultra Mini Projector has been overwhelmingly positive. It’s a fantastic little device that packs a punch in terms of performance and functionality. While it has its minor drawbacks, the advantages far outweigh them, making it an excellent choice for anyone looking for a portable, versatile projector. Whether for family movie nights, presentations, or outdoor activities like camping, this projector has proven to be a reliable companion. I wholeheartedly recommend it to anyone in need of a quality compact projector.
• Excellent picture clarity and brightness.
• Highly portable and easy to set up.
• Supports HDMI and USB connections.
• Comes with a mini tripod.
• Exceptional customer service experiences reported.
• Remote control functionality needs improvement.
• Battery life is limited, often only lasting about an hour.
• Some applications, like Netflix, may not function properly due to outdated software.
• Adjusting focus and alignment can be finicky and time-consuming.
Overall, this projector excels in portability and image quality, making it an excellent choice for artists, casual movie watchers, or those looking to enhance their hobbies, like cookie decorating. While there are notable drawbacks, such as battery limitations and remote control issues, the projector's strong performance in terms of clarity and ease of use, combined with a remarkable customer service experience, makes it a worthy investment. For anyone working on small-scale projects or seeking an outdoor entertainment solution, this product comes highly recommended, as long as users are aware of its battery constraints and software limitations.
Elfman72
I’m loving the TMY Ultra Mini Projector! It’s super tiny and fits right in my pocket. I take it everywhere and it’s perfect for extending my laptop display. It’s battery-powered, so I can set it up anywhere. My family loves it too! Totally happy with this buy!
MsPippiton1117
The AKASO WT50 Mini Projector is awesome! It hooks up to my phone super easily and I use it for my cookie decorating. It looks great and is super compact. Plus, the sound is surprisingly powerful for such a tiny gadget. I've told tons of my cookie-loving friends about it!
goalweiser
I’m obsessed with my AKASO WT50 Mini Projector! It’s perfect for what I needed. I can throw it in my backpack, go for a bike ride, and chill in the woods to watch something.
