Competitive_Tax
- 1 Specs
- 2 Which to get
In today's video, we're diving into a head-to-head comparison of two mini projectors that promise to deliver impressive viewing experiences but come with distinct features that may sway your choice. On one side, we have the Generic Mini Smart Projector, boasting a robust Android 11 operating system with built-in streaming apps, a powerful 10,000 lumens brightness, and support for a whopping 150-inch display. Its innovative design allows for short-throw projection and versatile 180° rotation, making it a strong contender for those who value flexibility and high performance in smaller spaces.
On the other side, we have the YOVDA Smart Mini Projector, a portable option that touts easy adjustability with automatic keystone correction and a manual focus feature. While it projects up to 130 inches, it shines in adaptability for various environments, whether indoors or outdoors. The YOVDA also supports full HD display but at a more compact scale compared to its competitor.
So, which projector delivers the best overall value and viewing experience? Stick around as we unpack the strengths and weaknesses of each, helping you make an informed decision on which mini projector best fits your lifestyle.
I’m on the hunt for a mini projector and came across two options that have me torn: the Generic Mini Smart Projector and the YOVDA Smart Mini Projector. I’m primarily focused on picture quality, sound quality, the overall system, and any potential downsides.
The Generic Mini Smart Projector boasts 10,000 lumens with 1080P resolution and a native contrast ratio of 10000:1, which sounds amazing for vibrant colors and clarity. Plus, it runs on Android 11, so I can access apps like Netflix directly. The short-throw feature is a nice touch for smaller spaces too.
On the flip side, the YOVDA promises portability with a 130-inch projection capability and auto keystone correction, which is super handy for quick setups. It supports 1080p and has manual focus, but I’m not sure how it compares in sound quality or if it has any built-in streaming capabilities like the Generic.
I’d love to hear your thoughts on which one might be the better buy or if there are any glaring downsides I should be aware of! Thanks!
Specs
Parameter | Generic Mini Smart Projector | YOVDA Smart Mini Projector Portable Projector |
Reference Price | - | $79.99 |
Recommended Uses | Education, Home Cinema, Gaming, Business | Home Cinema |
Built-In Media | User Manual, Power Cord, Remote | User Manual |
Highlight | 【Android 11 smart projector with Wif6 & Eshare】 Smart Android projector Gimbal5 is embedded with Android 11.0 operating system pre-installed with Netflix, Youtube and other applications, and enjoy massive video resources through more than 8000+ applications. It has the latest 5G dual-band WiFi 6, bringing more High transfer rate and lower latency, Supports Eshare wireless mirroring function to easily share your smartphone content to the big screen. 【10000 Lumens Full HD 1080P Projector】The 1080P Full HD projector is equipped with a compact LCD screen with a native resolution of 1920 x 1080 pixels, as well as a 18000 lumens light source and a high dynamic contrast ratio of 10000:1. The innovative light engine structure design allows the mini projector to support a display screen of up to 150 inches, providing extraordinary vivid color reproduction and a clear experience. 【Short-Throw & 180° Rotation Support】Our short-throw projector can display a larger image from the same projection distance, allowing you to enjoy a big-screen experience even in smaller rooms. Additionally, its versatile stand supports 180° rotation, enabling you to use any wall or ceiling as your screen. Whether sitting or lying down, in the living room or bedroom, you can comfortably immerse yourself in the viewing experience. | ✪【Mini Portable Projector】The Y5S portable projector can project a 130-inch image from 2.0 to 13.1 feet between the projector and the screen. If you want a very large picture, or if you have a small space, then this is perfect for you. ✪【Auto Keystone Correction】The projector supports automatic keystone correction, you can also manually adjust the angle of the projector will automatically detect and correct distorted images with the touch of a button. ✪【Support Full HD Display】You can raise or lower the image, and a manual focus. Provide a perfect, straight-edged image with uniform focus. supports 1080p/720p @60fps decoding, you can watch videos during the day and outdoors. providing clear picture and a high-quality color experience. |
Screen Size | 30 32nds - 130 Inches | - |
Throw Distance | 1.2 - 4 | 2 - 13 |
Contrast Ratio | 1080p Pixels | 6000:1 |
Maximum Resolution | 1980 x 1080 Pixels | 1280 x 720 |
Native Resolution | 1920 x 1080 | 1280 x 720 |
Brightness | 10000 Lumen | 10000 lumen |
Display Type | LED | LED |
Other Features | Support 4K,Built-In BT 5.0, 5G WIFI + 2.4G WiFi, Auto Keystone Correction, 180° Rotation, Built-In Wi-Fi | Built-In Wi-Fi、Built-In Speaker、 Portable、 Digital Keystone Correction、 Built-In Cooling System、 Ultra Short Throw |
Video Encoding | - | AVC |
LightSource Life | 50000 Hours | 50000 Hours |
Controller Type | Remote Control | Remote Control, Button Control |
Control Method | Remote | Remote, Touch |
Connectivity Technology | Bluetooth, Wi-Fi, USB, HDMI | Wi-Fi |
Compatible Devices | - | Laptop, Tablet, Smartphone |
Wattage | - | 5 watts |
Mount Type | Ceiling Mount Floor Mount Tabletop Mount Tripod Mount Wall Mount | Tabletop Mount |
Which to get
Hey everyone.I’m on the hunt for a mini projector and came across two options that have me torn: the Generic Mini Smart Projector and the YOVDA Smart Mini Projector. I’m primarily focused on picture quality, sound quality, the overall system, and any potential downsides.
