Generic HY300 Plus vs USB T500: Which Portable Projector Offers Better Resolution and Smart Features for Home Cinema?
  1. 1 Specs
  2. 2 Which to get
In the world of portable projectors, two products are vying for your attention: the Generic HY300 Plus and the USB T500. Both claim to elevate your viewing experience, but they do so in notably different ways. The HY300 Plus boasts a massive 200-inch screen capability, advanced 4K resolution support, and a robust built-in speaker system, making it a strong contender for those who prioritize performance and versatility. It also features cutting-edge WiFi connectivity for seamless streaming, perfect for movie nights or outdoor events.
On the flip side, the USB T500 leans heavily into portability, designed to be incredibly lightweight and compact, making it ideal for on-the-go entertainment. It supports easy mirroring from smartphones and offers a decent resolution for casual viewing, but lacks some of the high-end features found in the HY300 Plus.
So, is it better to invest in the powerhouse that is the HY300 Plus or the ultra-portable convenience of the USB T500? Let's dive into the specifics and see which projector truly deserves a spot in your home or travel bag.
Specs​
Generic HY300 Plus Portable Projector​
USB T500 Projector​
Business Education Gaming Home Cinema​
Power Cord, Remote, Device cover​
200'' GIANT SCREEN: Featuring a 180° rotatable design, allowing you to point the projector in any direction including the ceiling. Supporting 4K picture, really big or small in any area of your house. ANDROID 11 & FAST WIFI BAND: It has a built-in dual 5G+2.4G and WiFi 6 connection. Watch your favourite shows in Ultra-fast 5G WiFi. A much smoother, lag-free and reliable streaming experience.
BUILT-IN SPEAKER: With built-in 5W stereo speakers with a HiFi system for a great auditory sense experience: ultra clear sound. Connect headphones and speakers. Excellent for outdoor events. HD 1080P RESOLUTION & 4K VIDEO DECODING: Immerse yourself in stunning visuals as our projector supports high-definition 1920x1080P resolution. Full-format decoding including HEVC/VP9/AVS2/AVC 4K@30fps and AV1/MPEG1/MPEG2 1080p/60fps decoding and so on. Elevate your viewing with sharper details and embrace the future of projection technology.
PORTABLE SIZE: It's compact enough to be packed in a bag for travel or bringing on camping trips. And with a light source life of up to 50,000 hours. Easily meet your movie, match, and game needs. AUTO CORRECTION: It offers auto horizontal keystone correction and manual trapezoidal correction, which can help you easily set up the correct proportions and angles.
【♥】projected small screen to big screen,supporting wire mirroring funcition,support android iOS dervices,built in composite diaphragm loudspaker,built in independent cavity audio+ high quauty speakers,strong performance and stable operation.
【♥】portable and carefree, 4.8cm ,sum puselage 0.25kg .Palm thickness,can be held with one hand or put in a pocket,travel more power supply can be seen everymhere,you own private cinema,take the power bank with you and see where you go support 5V power supply.
【♥】makes it possible for you to display high definition movie clips and pictures on your walls, entertainment center, or gaming room. This projection makes it easy to share great moments with friends and family. Get a clear and bright image with a resolution of 1920x1080. This projectors noise is less than 25dbs.
30 32nds - 200 Inches​
16 Inches - 100 Inches​
1.2 - 4​
N/A - 9.8 Feet​
1080*720p Pixels​
1980 x 1080​
1280 x 720​
10000 Lumen​
LED​
Dust-Proof, Portable, Auto Focus, Built In Wi Fi, Built-In Media Player​
AVC​
5E+4 Hours​
Bluetooth, Wi-Fi, HDMI
USB​
Laptop, Gaming Console, Tablet, Smartphone​
18 watts​
Mount Type​
Ceiling Mount Floor Mount Tabletop Mount​
Tabletop Mount​
Which to get​
Looking to upgrade my movie nights and I’m torn between two projectors: the Generic HY300 Plus Portable Projector and the USB T500 Projector.
The HY300 boasts an impressive 200'' giant screen and supports 4K picture quality. It’s got this cool 180° rotatable design, making it super versatile for different viewing angles. Plus, with built-in 5W stereo speakers and HiFi sound, I’m expecting a good auditory experience. It runs on Android 11 with dual-band WiFi for smooth streaming. But, how does it really perform in terms of picture quality and sound in real-life settings? And do those built-in speakers hold up for outdoor use?
On the flip side, the USB T500 is ultra-portable at just 0.25kg and can easily fit in my pocket. It supports wire mirroring for quick connections and has high-quality speakers with an operational noise below 25dB, which is pretty quiet. It also offers 1080p resolution, but I’m curious if it can compete with the HY300’s 4K capabilities.
What do you think? Are the extra features of the HY300 worth it, or is the lightweight and compact nature of the USB T500 more appealing for casual use? Any potential downsides I should be aware of with either? Appreciate any insights!
