Adney
As the pioneer of "laser smart projector", Formovie launched the new P1 laser projector this year. Let's see the review.
The P1 is compact, measuring only 150.8x83x24.6mm, not much bigger than a cell phone. Solid buttons, no need to use remote control.
Formovie P1 has a built-in Type-c power supply interface, which can be powered by Type-C PD rechargeable batteries, making it more convenient to carry around.
The projector adopts a 1.2:1 projection ratio, has a 40-100 inch projectable screen, and supports multiple screen projection methods.
Formovie P1 projector uses ALPD laser display technology with brightness up to 800ANSI. The technology features better light efficiency, wider color gamut and higher contrast ratio, and it makes the projector comprehensively smaller and more efficient. Laser projectors are 30%-50% smaller than LED projectors at the same brightness.
It also has a built-in speaker that can act as a Bluetooth speaker for your phone, so you don't have to carry a speaker when you go out.
