Significant_Rate
Highlight
- 1.1.1 Epson Pro EX9240 Projector:
- 1.1.2 Epson VS250 Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Epson Pro EX9240 Projector:
- 1.3.2 Epson VS250 Projector:
- 1.4 Features
1.5
- 1.5.1 Epson Pro EX9240 Projector:
- 1.5.2 Epson VS250 Projector:
1.1
Highlight
- 2 Conclusion
Parameter | Epson Pro EX9240 Projector | Epson VS250 Projector |
Reference Price | $849.99 | $525 |
Recommended Uses | Business, Home Cinema | business presentations, classroom presentations, home theaters |
Built-In Media | Pro EX9240 projector, power cable, projector remote control, batteries, Quick Start Guide | Quick Setup Sheet, computer cable (VGA), batteries, User Manual CD, VS250 projector, projector remote control, power cable |
Highlight
Dynamic Contrast Ratio: up to 16,000:1Picture Skew Sensor: built-in, auto vertical keystone correction
Image Adjustments: easy controls, 1-1.6x optical zoom, horizontal slider, auto vertical correction
Wireless Connectivity: screen mirroring (Miracast), 2 HDMI ports
Speaker Power: built-in 16 W speaker
Smart Control: Caseta smart switch for multiple bulb control, compatible with various bulb types
Brightness: 3,200 lumensFan Noise: ECO mode 28 dB, Normal mode 37 dB
Resolution: SVGA (800 x 600)
Projected Distance: 30 inch to 350 inch (0.88 to 10.44 m)
Compatibility: PC, Mac, iProjection App (iOS & Android)
F Number: 1.44
Focal Length: 16.7 mm
Digital Zoom Ratio: 1.0 to 1.35
Pixel Number: 480,000 dots
Setup: Fast and easy with image adjustments
Connectivity: HDMI
Speaker: 2 W (Mono)
Power Supply Voltage: 100 to 240 V ±10%, 50/60 Hz
Power Consumption: ECO mode 211 W, Normal mode 296 W
Operating Temperature: 41°F to 95°F (5°C to 35°C)
Screen Size | N/A - 300 Inches | 30 Inches - 300 Inches |
Throw Distance | 1.32 Meters - 2.14 Meters | - |
Contrast Ratio | - | 15000:1 |
Maximum Resolution | 1920 x 1080 | 800 x 600 |
Native Resolution | 1920 x 1080 | SVGA - SVGA (800 x 600) (native) / 1400 x 1050 (resized) |
Brightness | - | 3200 Lumen |
Display Type | LCD | LCD |
Viewing Experience
The viewing experience was truly impressive, with the projector delivering bright and clear images even in well-lit environments. I was able to project content onto a textured shower curtain, and the quality remained sharp and vibrant. The split-screen feature added versatility, allowing me to display multiple sources simultaneously. However, I did find the built-in speakers lacking in quality, necessitating the use of a Bluetooth speaker for a more immersive audio experience.Epson VS250 Projector:
The viewing experience with the VS250 surpassed my expectations, especially given its budget-friendly price. The brightness is impressive, allowing for use even in moderately lit rooms without sacrificing image quality. Colors are vivid and contrast is strong, making movies and presentations pop visually. While the resolution of 800 x 600 is not the highest, I found it more than adequate for streaming videos and viewing dynamic content. The projector's performance remained consistent, producing a clear image from a distance of about 11 feet, which made it suitable for both casual movie nights and professional presentations.Features
Other Features | Portable, Bluetooth | Portable, Lightweight |
Lamp Wattage | 380 Watts | 200 Watts |
LightSource Life | - | 6E+3 Hours |
Controller Type | - | Button Control |
Control Method | - | App, Touch |
Connectivity Technology | HDMI | HDMI |
Compatible Devices | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Laptop, Gaming Console, Smartphone, Tablet |
Wattage | 16 watts | 2 watts |
Mount Type | - | Tabletop Mount |
L x W x H | 12.2"L x 11.2"W x 3.5"H | 11.9"L x 9.2"W x 3.2"H |
Setting up the projector was relatively straightforward, although I did encounter some hiccups when connecting it to my MacBook. The built-in WiFi feature was a significant advantage, allowing for direct connections without the need for cumbersome cables. However, I did notice some issues with the HDMI connections and the overall menu navigation, which could be confusing at times, especially when adjusting settings like keystone correction. Despite these challenges, I appreciated the prompt and helpful technical support from Epson.Epson VS250 Projector:
Setting up the Epson VS250 was a breeze. I appreciated the intuitive nature of the controls; I was able to connect it to my laptop and other devices with minimal hassle. The inclusion of different connection options, including HDMI, made it flexible for my needs. I did have to purchase a separate HDMI cable, which was a small extra step. The projector was functional right away, and I found it easy to adjust the image to fit my screen or wall, ensuring a quick start to my movie nights or presentations.Conclusion
Pros:• Bright and sharp image quality, even in ambient light
• Easy to set up and connect to various devices
• Split-screen feature enhances functionality
• Quiet operation compared to older models
• Built-in audio quality is subpar; requires external speakers
• HDMI connection issues and menu navigation can be confusing
• No audio output options; workaround needed for external sound
• Some users reported noise from the fan
Overall, I found this projector to exceed my expectations in terms of brightness and clarity, making it an excellent choice for both educational and casual use. While it has its drawbacks, particularly regarding audio capabilities and setup challenges, the vibrant image quality and ease of use make it a worthwhile investment. Given my positive experience and the support from Epson, I believe this projector will serve me well for years to come, especially as I continue to use it in various teaching environments.
Pros:• High build quality and design feel satisfying.
• Brightness and color performance are excellent in various lighting conditions.
• Quiet fan operation compared to cheaper projectors.
• Easy setup and multiple connection options.
• Mounting thread is not universal, which may complicate tripod use.
• Limited resolution may not meet all professional needs.
• Lack of audio output port limits external speaker connection.
• No wireless functionality for direct smartphone mirroring.
I am thoroughly impressed with the Epson VS250 projector. It represents a significant upgrade from my previous low-cost projector and provides excellent value for its price. The projector performs well in both home theater and business settings, making it versatile for different uses. While there are a few drawbacks, particularly regarding audio output and resolution, they do not detract significantly from the overall experience. I would highly recommend this projector for anyone looking for a reliable and capable option for movies or presentations without breaking the bank.
